Topic: Problem with simple LED circuit (Read 1 time) previous topic - next topic
Tanjim
Mar 27, 2012, 01:05 pm Last Edit: Mar 27, 2012, 02:14 pm by Tanjim Reason: 1
Hey,
I'm currently working with Arduino for a simple project, where I need to have an array of lights, and make the lights switch to the next one when a button is pressed.
Like the following:
0 = LED that's off
1 = LED that's on
000000010
*Press right button*
000000001
100000000
*Press left button*
000000001
*Press left button*
000000010
Etc.
Now I've gotten everything connected to the arduino, I'm rather sure there's nothing wrong with the buttons.
I've written the following code:
Code: [Select]
 int x=3;
int del=700;
int buttonState = 0;
int buttonState2 = 0;
pinMode(2,OUTPUT);
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(7,OUTPUT);
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
pinMode(12,INPUT);
pinMode(13,INPUT);
buttonState = digitalRead(12);
if (buttonState == HIGH) {
if (x == 10) {
digitalWrite(10,LOW);
digitalWrite(2,HIGH);
x = 2;
delay(del);
else {
digitalWrite(x,LOW);
x = x+1;
digitalWrite(x,HIGH);
delay(del);
buttonState2 = digitalRead(13);
if (buttonState2 == HIGH) {
if (x == 2) {
digitalWrite(2,LOW);
digitalWrite(10,HIGH);
x = 10;
delay(del);
else {
x = x-1;
delay(del);
2-10 are the outputs for the buttons, 12 and 13 where the wires from the buttons go to.
When I only use the right button (second part of the code), it works fine.
When I use the left button too (doesn't matter if it's both right and left, or only left), it already starts going through the cycle as if I was constantly pressing the button, even though I don't press it at all.
Now I've use a volt meter thingy to make sure that there runs no current to port 12 when the button is not pressed, so the button isn't broken.
I've tried changing the output number from 12 to 11 too, but that didn't change anything either.
I think there's something wrong with code, but I can't figure it out.
Maybe any of you can see a flaw? It just compiles without an error.
It would be much appreciated if someone could help me with this.
If there's any more information you need to know, please ask me.
Thanks in advance,
Tanjim
georgekay
Have you tried switching the buttons?
I'm not sure if something with your code is wrong, but you could have the same function with a lot less code, which also makes it easier to find bugs:
Code: [Select]
int x=3;
int del=700;
  for (int i=2; i<11; i++) {
    pinMode(i, OUTPUT);
  pinMode(12, INPUT);
  pinMode(13, INPUT);
    digitalWrite(x, LOW);
    x++;
    if (x > 10) x = 2;
    digitalWrite(x, HIGH);
    delay(del);
    x--;
    if (x < 2) x = 10;
    delay(del);
Nishant_Sood
"Real Men can Accomplish  Anything"
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
udoklein
#3
Mar 27, 2012, 08:36 pm Last Edit: Mar 27, 2012, 08:43 pm by Udo Klein Reason: 1
Have a look at my version:
Code: [Select]
http://blog.blinkenlight.net/experiments/counting-resets/. However I do not use a standard IO pin for the button ;)
If I understand your code right you do not activate the pullups. Thus the button pins will be floating. Thus the erratic button behavior. In order to activate the pullups you need to add
Code: [Select]
digitalWrite(12, HIGH);
digitalWrite(13, HIGH);
It also looks as if you use the switches to pull the pins to 5V. If you follow my suggestion the switches must pull the pins to GND and the readings must be inverted.
Check out my experiments http://blog.blinkenlight.net
udoklein
I would also suggest to shorten the code to make it clearer what it actually does. Notice that my version has slightly poorer performance due to the way I render.
Code: [Select]
const int del=700;
  for (int pin=2; pin<11; pin++) {
    pinMode(pin, OUTPUT);
  pinMode(12, INPUT);
  pinMode(13, INPUT);
void render_output_and_delay(uint8_t x) {
  for (uint8_t led=2; led<11; ++led) {
      digitalWrite(led, led==x);
  delay(del);
  static int x=3;
  if (!digitalRead(12)) {
    x = (x<10? x+1: 2);
    render_output_and_delay(x);
  if (!digitalRead(13)) {
    x = (x>2? x-1: 10);
