Topic: Need help with a melody (Read 15913 times) previous topic - next topic
roli
I need a little help with arduino playing some noise. I want to play a first few seconds of this (on a piezo speaker) ;D:
http://www.youtube.com/watch?v=Mo8Qls0HnWo
Problem is that me and music are two different worlds. So if anyone can write some code that will play that - I will be extreamly grateful.
bhagman
#1
Apr 02, 2010, 08:33 pm Last Edit: Apr 02, 2010, 08:47 pm by bhagman Reason: 1
Try this.  I don't even know what the "Knight Rider" RTTTL sounds like, so don't yell at me if it's really cheezy.  There are other RTTTL's for Knight Rider (search for RTTTL Knight Rider).
I originally wrote this for the Tone library which has now been adapted and included in the core for Arduino.
So this is the core version of the RTTTL playback sketch (using the built-in tone(), noTone() features of Arduino).
b
Code: [Select]
// A fun sketch to demonstrate the use of the Tone library.
// By Brett Hagman
// bhagman@roguerobotics.com
// www.roguerobotics.com
// To mix the output of the signals to output to a small speaker (i.e. 8 Ohms or higher),
// simply use 1K Ohm resistors from each output pin and tie them together at the speaker.
// Don't forget to connect the other side of the speaker to ground!
// You can get more RTTTL (RingTone Text Transfer Language) songs from
// http://code.google.com/p/rogue-code/wiki/ToneLibraryDocumentation
#define OCTAVE_OFFSET 0
#define TONE_PIN 13
#define NOTE_C4  262
#define NOTE_CS4 277
#define NOTE_D4  294
#define NOTE_DS4 311
#define NOTE_E4  330
#define NOTE_F4  349
#define NOTE_FS4 370
#define NOTE_G4  392
#define NOTE_GS4 415
#define NOTE_A4  440
#define NOTE_AS4 466
#define NOTE_B4  494
#define NOTE_C5  523
#define NOTE_CS5 554
#define NOTE_D5  587
#define NOTE_DS5 622
#define NOTE_E5  659
#define NOTE_F5  698
#define NOTE_FS5 740
#define NOTE_G5  784
#define NOTE_GS5 831
#define NOTE_A5  880
#define NOTE_AS5 932
#define NOTE_B5  988
#define NOTE_C6  1047
#define NOTE_CS6 1109
#define NOTE_D6  1175
#define NOTE_DS6 1245
#define NOTE_E6  1319
#define NOTE_F6  1397
#define NOTE_FS6 1480
#define NOTE_G6  1568
#define NOTE_GS6 1661
#define NOTE_A6  1760
#define NOTE_AS6 1865
#define NOTE_B6  1976
#define NOTE_C7  2093
#define NOTE_CS7 2217
#define NOTE_D7  2349
#define NOTE_DS7 2489
#define NOTE_E7  2637
#define NOTE_F7  2794
#define NOTE_FS7 2960
#define NOTE_G7  3136
#define NOTE_GS7 3322
#define NOTE_A7  3520
#define NOTE_AS7 3729
#define NOTE_B7  3951
int notes[] = { 0,
NOTE_C4, NOTE_CS4, NOTE_D4, NOTE_DS4, NOTE_E4, NOTE_F4, NOTE_FS4, NOTE_G4, NOTE_GS4, NOTE_A4, NOTE_AS4, NOTE_B4,
NOTE_C5, NOTE_CS5, NOTE_D5, NOTE_DS5, NOTE_E5, NOTE_F5, NOTE_FS5, NOTE_G5, NOTE_GS5, NOTE_A5, NOTE_AS5, NOTE_B5,
NOTE_C6, NOTE_CS6, NOTE_D6, NOTE_DS6, NOTE_E6, NOTE_F6, NOTE_FS6, NOTE_G6, NOTE_GS6, NOTE_A6, NOTE_AS6, NOTE_B6,
NOTE_C7, NOTE_CS7, NOTE_D7, NOTE_DS7, NOTE_E7, NOTE_F7, NOTE_FS7, NOTE_G7, NOTE_GS7, NOTE_A7, NOTE_AS7, NOTE_B7
//char *song = "The Simpsons:d=4,o=5,b=160:c.6,e6,f#6,8a6,g.6,e6,c6,8a,8f#,8f#,8f#,2g,8p,8p,8f#,8f#,8f#,8g,a#.,8c6,8c6,8c6,c6";
//char *song = "Indiana:d=4,o=5,b=250:e,8p,8f,8g,8p,1c6,8p.,d,8p,8e,1f,p.,g,8p,8a,8b,8p,1f6,p,a,8p,8b,2c6,2d6,2e6,e,8p,8f,8g,8p,1c6,p,d6,8p,8e6,1f.6,g,8p,8g,e.6,8p,d6,8p,8g,e.6,8p,d6,8p,8g,f.6,8p,e6,8p,8d6,2c6";
//char *song = "Entertainer:d=4,o=5,b=140:8d,8d#,8e,c6,8e,c6,8e,2c.6,8c6,8d6,8d#6,8e6,8c6,8d6,e6,8b,d6,2c6,p,8d,8d#,8e,c6,8e,c6,8e,2c.6,8p,8a,8g,8f#,8a,8c6,e6,8d6,8c6,8a,2d6";
//char *song = "Looney:d=4,o=5,b=140:32p,c6,8f6,8e6,8d6,8c6,a.,8c6,8f6,8e6,8d6,8d#6,e.6,8e6,8e6,8c6,8d6,8c6,8e6,8c6,8d6,8a,8c6,8g,8a#,8a,8f";
//char *song = "Bond:d=4,o=5,b=80:32p,16c#6,32d#6,32d#6,16d#6,8d#6,16c#6,16c#6,16c#6,16c#6,32e6,32e6,16e6,8e6,16d#6,16d#6,16d#6,16c#6,32d#6,32d#6,16d#6,8d#6,16c#6,16c#6,16c#6,16c#6,32e6,32e6,16e6,8e6,16d#6,16d6,16c#6,16c#7,c.7,16g#6,16f#6,g#.6";
//char *song = "MASH:d=8,o=5,b=140:4a,4g,f#,g,p,f#,p,g,p,f#,p,2e.,p,f#,e,4f#,e,f#,p,e,p,4d.,p,f#,4e,d,e,p,d,p,e,p,d,p,2c#.,p,d,c#,4d,c#,d,p,e,p,4f#,p,a,p,4b,a,b,p,a,p,b,p,2a.,4p,a,b,a,4b,a,b,p,2a.,a,4f#,a,b,p,d6,p,4e.6,d6,b,p,a,p,2b";
//char *song = "StarWars:d=4,o=5,b=45:32p,32f#,32f#,32f#,8b.,8f#.6,32e6,32d#6,32c#6,8b.6,16f#.6,32e6,32d#6,32c#6,8b.6,16f#.6,32e6,32d#6,32e6,8c#.6,32f#,32f#,32f#,8b.,8f#.6,32e6,32d#6,32c#6,8b.6,16f#.6,32e6,32d#6,32c#6,8b.6,16f#.6,32e6,32d#6,32e6,8c#6";
//char *song = "GoodBad:d=4,o=5,b=56:32p,32a#,32d#6,32a#,32d#6,8a#.,16f#.,16g#.,d#,32a#,32d#6,32a#,32d#6,8a#.,16f#.,16g#.,c#6,32a#,32d#6,32a#,32d#6,8a#.,16f#.,32f.,32d#.,c#,32a#,32d#6,32a#,32d#6,8a#.,16g#.,d#";
//char *song = "TopGun:d=4,o=4,b=31:32p,16c#,16g#,16g#,32f#,32f,32f#,32f,16d#,16d#,32c#,32d#,16f,32d#,32f,16f#,32f,32c#,16f,d#,16c#,16g#,16g#,32f#,32f,32f#,32f,16d#,16d#,32c#,32d#,16f,32d#,32f,16f#,32f,32c#,g#";
//char *song = "A-Team:d=8,o=5,b=125:4d#6,a#,2d#6,16p,g#,4a#,4d#.,p,16g,16a#,d#6,a#,f6,2d#6,16p,c#.6,16c6,16a#,g#.,2a#";
//char *song = "Flinstones:d=4,o=5,b=40:32p,16f6,16a#,16a#6,32g6,16f6,16a#.,16f6,32d#6,32d6,32d6,32d#6,32f6,16a#,16c6,d6,16f6,16a#.,16a#6,32g6,16f6,16a#.,32f6,32f6,32d#6,32d6,32d6,32d#6,32f6,16a#,16c6,a#,16a6,16d.6,16a#6,32a6,32a6,32g6,32f#6,32a6,8g6,16g6,16c.6,32a6,32a6,32g6,32g6,32f6,32e6,32g6,8f6,16f6,16a#.,16a#6,32g6,16f6,16a#.,16f6,32d#6,32d6,32d6,32d#6,32f6,16a#,16c.6,32d6,32d#6,32f6,16a#,16c.6,32d6,32d#6,32f6,16a#6,16c7,8a#.6";
//char *song = "Jeopardy:d=4,o=6,b=125:c,f,c,f5,c,f,2c,c,f,c,f,a.,8g,8f,8e,8d,8c#,c,f,c,f5,c,f,2c,f.,8d,c,a#5,a5,g5,f5,p,d#,g#,d#,g#5,d#,g#,2d#,d#,g#,d#,g#,c.7,8a#,8g#,8g,8f,8e,d#,g#,d#,g#5,d#,g#,2d#,g#.,8f,d#,c#,c,p,a#5,p,g#.5,d#,g#";
//char *song = "MahnaMahna:d=16,o=6,b=125:c#,c.,b5,8a#.5,8f.,4g#,a#,g.,4d#,8p,c#,c.,b5,8a#.5,8f.,g#.,8a#.,4g,8p,c#,c.,b5,8a#.5,8f.,4g#,f,g.,8d#.,f,g.,8d#.,f,8g,8d#.,f,8g,d#,8c,a#5,8d#.,8d#.,4d#,8d#.";
//char *song = "MissionImp:d=16,o=6,b=95:32d,32d#,32d,32d#,32d,32d#,32d,32d#,32d,32d,32d#,32e,32f,32f#,32g,g,8p,g,8p,a#,p,c7,p,g,8p,g,8p,f,p,f#,p,g,8p,g,8p,a#,p,c7,p,g,8p,g,8p,f,p,f#,p,a#,g,2d,32p,a#,g,2c#,32p,a#,g,2c,a#5,8c,2p,32p,a#5,g5,2f#,32p,a#5,g5,2f,32p,a#5,g5,2e,d#,8d";
char *song = "KnightRider:d=4,o=5,b=125:16e,16p,16f,16e,16e,16p,16e,16e,16f,16e,16e,16e,16d#,16e,16e,16e,16e,16p,16f,16e,16e,16p,16f,16e,16f,16e,16e,16e,16d#,16e,16e,16e,16d,16p,16e,16d,16d,16p,16e,16d,16e,16d,16d,16d,16c,16d,16d,16d,16d,16p,16e,16d,16d,16p,16e,16d,16e,16d,16d,16d,16c,16d,16d,16d";
void setup(void)
#define isdigit(n) (n >= '0' && n <= '9')
void play_rtttl(char *p)
 // Absolutely no error checking in here
 byte default_dur = 4;
 byte default_oct = 6;
 int bpm = 63;
 int num;
 long wholenote;
 long duration;
 byte note;
 byte scale;
 // format: d=N,o=N,b=NNN:
 // find the start (skip name, etc)
 while(*p != ':') p++;    // ignore name
 p++;                     // skip ':'
 // get default duration
 if(*p == 'd')
   p++; p++;              // skip "d="
   num = 0;
   while(isdigit(*p))
     num = (num * 10) + (*p++ - '0');
   if(num > 0) default_dur = num;
   p++;                   // skip comma
 Serial.print("ddur: "); Serial.println(default_dur, 10);
 // get default octave
 if(*p == 'o')
   p++; p++;              // skip "o="
   num = *p++ - '0';
   if(num >= 3 && num <=7) default_oct = num;
   p++;                   // skip comma
 Serial.print("doct: "); Serial.println(default_oct, 10);
 // get BPM
 if(*p == 'b')
   p++; p++;              // skip "b="
   num = 0;
   while(isdigit(*p))
   bpm = num;
   p++;                   // skip colon
 Serial.print("bpm: "); Serial.println(bpm, 10);
 // BPM usually expresses the number of quarter notes per minute
 wholenote = (60 * 1000L / bpm) * 4;  // this is the time for whole note (in milliseconds)
 Serial.print("wn: "); Serial.println(wholenote, 10);
 // now begin note loop
 while(*p)
   // first, get note duration, if available
   num = 0;
   while(isdigit(*p))
   if(num) duration = wholenote / num;
   else duration = wholenote / default_dur;  // we will need to check if we are a dotted note after
   // now get the note
   note = 0;
   switch(*p)
     case 'c':
       note = 1;
     case 'd':
       note = 3;
     case 'e':
       note = 5;
     case 'f':
       note = 6;
     case 'g':
       note = 8;
     case 'a':
       note = 10;
     case 'b':
       note = 12;
     case 'p':
     default:
       note = 0;
   p++;
   // now, get optional '#' sharp
   if(*p == '#')
     note++;
     p++;
   // now, get optional '.' dotted note
   if(*p == '.')
     duration += duration/2;
     p++;
   // now, get scale
   if(isdigit(*p))
     scale = *p - '0';
     p++;
     scale = default_oct;
   scale += OCTAVE_OFFSET;
   if(*p == ',')
     p++;       // skip comma for next note (or we may be at the end)
   // now play the note
   if(note)
     Serial.print("Playing: ");
     Serial.print(scale, 10); Serial.print(' ');
     Serial.print(note, 10); Serial.print(" (");
     Serial.print(notes[(scale - 4) * 12 + note], 10);
     Serial.print(") ");
     Serial.println(duration, 10);
     tone(TONE_PIN, notes[(scale - 4) * 12 + note]);
     delay(duration);
     noTone(TONE_PIN);
     Serial.print("Pausing: ");
     delay(duration);
void loop(void)
 play_rtttl(song);
 Serial.println("Done.");
 while(1);
http://wiring.org.co/ - Wiring - Where Arduino came from. (Wiring begat Arduino)
http://loftypremises.com/ - Everything you wanted to know about me.... and less
http://roguerobotics.com/ - #1 Canadian Arduino distributor
roli
#2
Apr 02, 2010, 10:17 pm Last Edit: Apr 02, 2010, 10:33 pm by roli Reason: 1
Wow!
Nice piece of code! For the past half an hour I have been trying so many different theme songs  :). And searching for the best one.
EDIT: I don't like the Knight Rider - probablt because it doesn't sound anything like what it should sound like. But I do like Macgyver (probably because the theme song is more beepy in the original - you can almost recognize it ;D).
amacmullen14
Yeah, the macgyver one could be easily represented through beeps.
roli
I found this one:
Code: [Select]
MacGyver:d=4,o=6,b=127:8c,8c,8c,8c,8c,8c,2b5,8f_5,8a5,8p,2g5,8c,8c,8p,b5,8a5,8b5,8a5,8g5,8p,e,a.5,16p,b.5,16p,c,8b5,8a5,c
It is nice but it is too short. :)
majorgray3
Quote
I found this one:
Code:
I finished the short clip of the MacGyver theme. I think it sounds pretty close to the original theme song.
Code: [Select]
char *song = "MacGyver:d=4,o=6,b=150:8b4,8e5,8a5,8b5,a5,8e5,8b4,8p,8e5,8a5,8b5,8a5,8e5,b4,8p,8e5,8a5,8b5,a5,8e5,8b4,8p,8a5,8d,8c,8d,8c,8b5,8a5,8b4,8e5,8a5,8b5,a5,8e5,8b4,8p,8e5,8a5,8b5,8a5,8e5,b4,8p,8e5,8a5,8b5,a5,8e5,8b4,8p,8a5,8d,8c,8d,8c,8b5,8a5,b5,8p,2b5,8p,b5,8p,a5,d.,b5,8p,2b5,8p,8b5,8p,2a5,p,8c,8c,8c,8c,8c,8c,2b5,16p,8f#5,8a5,8p,2g5,8p,8c,8c,8p,b5,8a5,8b5,8a5,8g5,8p,e,2a5,16p,8c,8c,8p,2b5,8p,8f#5,8a5,8p,2g5,8p,8c,8c,8p,4b5,8a5,8b5,8a5,8g5,8p,4e,2a5,2b5,32p,8c,8b5,8a5,c,8b5,8a5,8d,8c,8b5,d,8c,8b5,e,8d,8e,f#,b5,g,8p,f#,f,b5,8g,8e,8b5,8f#,8d,8a5,8e,8c,8g5,8d,8b5,8g5,8c,8e5,8b5,8d5,8c,8b5,8a5,8g5,a#5,a5,8g,8g5,8d,8g5,8d#,8d#5,8a#5,8a5,8g5,8g4,8d5,8g4,8d#5,8g4,8a#4,8a4,8g4,8g4,8g4,8g4,8g4,8g4,8g4";
Tell me what you guys think.
Adrastos
XD
Played around with this today - WAY too much fun!!
keeper63
Somebody should put this in the playground (with the macgyver theme added)...
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
Osgeld
not to toss this thread off topic, but cr0sh, check your PM!
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
majorgray3
I posted a video of my setup playing the MacGyver theme.
http://www.youtube.com/watch?v=HUu6Ma72-8A
