Topic: Controling motors with MOSFET (Read 2020 times) previous topic - next topic
boyma
Mar 30, 2012, 08:22 pm Last Edit: Mar 30, 2012, 08:24 pm by boyma Reason: 1
Hello
i need help to make a circuit.
in this scheme i control motor with MOSFET.i have one accumulator.Motor rotates in one side.How can i change rotation of motor?
zoomkat
Quote
H-bridge if you want to change the rotation direction. PWM if you just want to change the rotation speed in one direction.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
boyma
Quote
transistor can transmit current from drain to source  and we cant use PWM, no?
can i use this scheme?
CrossRoads
That is the scheme, basically. The Upper MOSFETs are generally P-channel and source current to the motor, while the Lower MOSFETs are N-Channel and sink current from the motor.
You need to use Logic Level MOSFETS and +U must be the same as the Arduino Vcc.
If you want Higher +U, then you need transistors in front of the P-Channels so the gates can go fully high (up to U+) to turn the P-channels off.
You can use PWM.
boyma
i don't understand how we can use transistors in front of the P-Channels.Can you draw scheme, please?
CrossRoads
So basically like this.
When a control line is high, the N-channel MOSFET gate is High and turned on, and the NPN Base is turned on to bring the P-channel gate Low to turn it on.
When a control line is low,  N-channel MOSFET gate is Low and turned off, and the NPN Base is not turned on, allowing the resistor to pull the the P-channel gate High to turn it off.
zoomkat
Some previous h-bridge projects that might be useful for information.
http://arduino.cc/forum/index.php/topic,53425.0.html
http://arduino.cc/forum/index.php/topic,74454.0.html
MarkT
You circuit has the p-channel MOSFET's drains connected to the positive supply rail - it should be the sources.
CrossRoads
Thanks MarkT.  Got it fixed.
