Topic: Programming using AVRDUDE / unix help (Read 1 time) previous topic - next topic
cowasaki
If I perform the following command:
bin/avrdude -Cbin/avrdude.conf -patmega328p -carduino -P/dev/cu.usbserial-A50066PH -b115200 -Uflash:w:hex/Controller_V092.hex:i
it programs the hex file "Controller_V092.hex" to the chip
BUT
I want to erase the EEPROM storage area at the same time in case the variables have changed.....
I've read AVRDUDE's manual but everything I've tried fails to work.
Also anyone know how I could create a unix batch file to do the following:
list the ".hex" files in the "hex" directory
allow the user to type one of them by name
check the existence of the filename they type
use that filename in the above command
Many thanks....
madworm
Code: [Select]
-e      Causes a chip erase to be executed.  This will reset the contents of the flash ROM and EEPROM to the value '0xff',
          and clear all lock bits. [...]
And to be sure that the EEPROM data says sayonara, you must make sure that the 'preserve EEPROM data' fuse is not active.
bperrybap
#2
Mar 31, 2012, 07:13 pm Last Edit: Mar 31, 2012, 07:23 pm by bperrybap Reason: 1
From looking at the command line options you are using, it looks like you are using the arduino bootloader
on the serial port.
While it works good enough to upload application images,
the arduino bootloader does not fully support all the stk500 commands.
(It cheats/lies in some cases)
There are things that simply don't work (and sometimes can't -  like fuses) when using a bootloader
that will work if using an ISP programmer.
I ran into a similar problem when I attempted to use the erase cycle option in avrdude
which tracks erase cycles in EEPROM. Because the bootloader doesn't support EEPROM updates
it can't be used.
While I don't have a board set up at this moment, I'd hope that the -e option fails when using the "arduino"
protocol. But after a quick look at the avrdude source code, it looks like it may silently fail.
--- bill
cowasaki
Thanks. Sounds about right. I tried -e and anything else. Will just have to do it another way ie write version number to EPROM and on boot if current version number doesn't match call EPROM reset routine :-)
cowasaki
Well I created a script that does as much as I can...
http://arduino.cc/forum/index.php/topic,99590.0.html
