Topic: send command via rs232 (Read 18788 times) previous topic - next topic
Grumpy_Mike
connect your TX and RX together...?
Take a wire from the RS232 TX output and connect it to the RS232 TX input.
Then send a byte out, read a byte back and print it out so you can see it on the serial monitor. If everything is working and wired up correctly you should get the same byte back as you sent out.
If you get nothing then it is wired up wrong, broken or something else.
If you get back what you sent then your problem is with the connection between your device and the RS232.
http://en.wikipedia.org/wiki/Loopback
amjlopez
thank you.
I have done the following:
I have connected Arduino to another PC through rs232 and I send data from Arduino and the PC receive and respond.
I'm using a serial program DataViewer (like Hyperterminal) .
Do you know What I am doing wrong with my Extron devices?
many thanks
Grumpy_Mike
You are not testing your external rs232 converter through the pins you have it wired up to using the software serial. That is what you need to test.
amjlopez
excuse me but I don't understand. Is my first time doing this.
thanks again
amjlopez
How can I Take a wire from the RS232 TX output and connect it to the RS232 TX input?
PaulS
Darn. I need to get a new Arduino. None of mine have a smiley face pin to use with NewSoftSerial.
amjlopez
Thank you.
I have read in somewhere that I can use pin0 and pin 1 to send data to an external device with rs232 is that true?
If yes, maybe I have not to use newSoftSerial.
PaulS
True.
with rs232
False. You can't send RS232 signals with a TTL chip. You can send TTL level data to a MAX232 chip, which can then output RS232 levels to the device.
You can't talk to two devices using the same set of pins. You can't read from the Serial Monitor and send to your external device on the same set of pins.
zoomkat
You can send data to numerous devices connected in parallel to the serial pins. Receiving data can have issues.
Grumpy_Mike
Why are you having trouble with concept?
You use wire, you solder it from pin 2 to pin 3 on the 9 way D-type connector on your TTL to RS232 converter.
You connect the other pins of this converter to the pins you had before. You then can test if you are talking to this converter or not.
amjlopez
I only want to comunnicate with external device and control it. I don't care what method to use. I'am looking in some books, Google and forums and I cannot comunnicate yet with the device.
Grumpy_Mike
Yes and you have implemented something that if you have actually wired it up like you say should work. What we are trying to do is to help you test it to see where you have gone wrong.
One way to do this is a loop back test but you have trouble in doing what was asked of you.
Your DFROBOT RS232-TTL Converter should be connected to some pins other than 0 & 1. This should be being driven by new software serial. You say it is not working so a loop back test would rule out wiring problems and software problems.
The DFROBOT RS232-TTL Converter has a 9 pin D-type socket on the end I am asking you to connect pin 2 & pin 3, You might need to have a plug to put the wires on or you can do it on the PCB side.
When you have confirmed that this setup is working you can then go on to investigate other things that could go wrong like a miss match in the baud rate or data format between your  DFROBOT and the thing you want to connect it to.
amjlopez
Thank you very much. I'll tried and I'll tell you.
amjlopez
I'm here again.
I have connected pin 2 to 3 to make a loopback. And when I test it I don't get response.
I have changed cables and not work.
This is the code I'm trying to test:
#include <SoftwareSerial.h>
SoftwareSerial MyDevice(7,8);  //  I don't know which is TX and RX...
// begin serial:
MyDevice.begin(9600);
  if (Serial.available() > 0) {
    switch (Serial.read()) {
    case 'a':
      MyDevice.print("1!");
      Serial.println("sent 1"); //to test in S.Monitor
      break;
    case 'b':
      MyDevice.print("5!");
      Serial.println("sent 5"); //to test in S.Monitor
      break;
    default:
      break;
thank you very much.
PaulS
Then, why the hell don't you try to find that out? Look at the source code!
Hardly surprising, since your code does not use pins 2 and 3.
