Topic: MIDI connection resistor (Read 2351 times) previous topic - next topic
yan_g
Hello,
I have a few questions regarding MIDI out...
Can I replace the 220 ohm resistor in that circuit with a 240 ohm resistor? What is this resistor for?
http://arduino.cc/en/Tutorial/Midi
In this other tutorial, the 5V and ground connections on the MIDI socket are switched. Does this circuit work the same?
http://itp.nyu.edu/physcomp/Labs/MIDIOutput
These questions must sound stupid so please enlighten me! Thanks!
pumpy
You might be able to get away with a 240 ohm, but MIDI usually uses 220.
The reason for this is that MIDI is designed to drive Opto Isolators, which are basically an LED and LDR in a chip.
So when that output socket is plugged into some other MIDI equipment, and a signal is sent, the current flows through the circuit, is limited by the resistor and lights the LED inside the Opto Isolator.  Using a different value MAY either cause damage to the Opto or it just won't light and your signal won't pass.
HTH?
P
Grumpy_Mike
Quote
Yes no problem.
Quote
No they are not it is just that the resistor is in the other side, this does not matter.
nickgammon
Say you buy 5% resistors. The highest a 220 ohm resistor might actually be is 220 * 1.05 = 231 ohms.
The lowest a 240 ohms resistor might be is 240 * 0.95 = 228 ohms.
Therefore it can't be too critical which one you use.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
