Topic: controlling LEDs from 12v battery using Arduino (Read 1 time) previous topic - next topic
sokbok
Hello good people.
I have a vision and I am in my basement and Im just banging my head.
I want to use solar energy to charge a 12V battery (already got that figured out).
I want to control LEDs being run off the 12V with my Arduino. I want to PWM 3 different sets of 5 LEDs.
I currently have a TIP125 transistor that Im trying to just get one set of 5 LEDs to change with.
What is the gain on this transistor, on the specs sheet it does not make sense.
Can I just use individual PWM pins on Arduion and have each use a separate Transistor?
Do I have the wrong transistor? What would be the ideal circuit. THANKS for any input or links or whatever. I
Grumpy_Mike
It has a gain greater than 1000.
However it is a PNP type Darlington, so you need to wire it up as such. This can not be used alone with an arduino to switch 12V.
sokbok
thanks Mike. Yes 1000 gain. I am totally willing to get another transistor to do this. can you recommend any?
Are you sayin that I need some resistors?
Grumpy_Mike
A BD679 is the sort of darlington you need, you will need a 4K7 resistor in the base, as well as this transistor.
