0.05" Header Pins?
I ordered this WiFi module without the breakout board and would like to connect some header pins to it to make it easier to work with. All header pins I can find come in 0.1" spacing which lines up perfectly with every other connection point. Do header pins exist with half the spacing? Should I just mount a row of headers on top and another on bottom each covering every other connection if not?
0.05" header pins do exist (see these for example), but they are a real pain to work with (at least in my experience). What are you going to connect to the header pins -- that's the real problem.
The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, speaker, microphone, light sensor, potentiometer, pushbuttons
I think that these kinds of modules are intended to be surface mounted.
Do you really need a full breakout though? If you're just using it as a wifi module, you only need a few contacts-- 3.3V, gnd, rx and tx.
