0-10v Output
I'd like to use arduino to drive a dimmable fluorescent lamp ballast. Any suggestions on getting 0-10v as an output.
Cheers
Stuart
you'll need an op-amp.. use google to search this forum, as this has been discussed before.
D
HI Stuart,
you should double check what kind of ballast you will use
on the market are
0-10 V and 1-10 V versions
0-10 V requires a voltage from your circuit
1-10 V provides a voltage which you have to control
i had once big trouble with a bunch of 20 wrong boxes
sold by our reseller as a 0-10 V dimmable ballast
clemens
