o.k. I give up. Why wont this code print "zero" ? Everything I try results in "one".
int Volume;
Volume = 0;
if (Volume = 0) Serial.println("zero");
if (Volume = 1) Serial.println("one");
cmiyc
2
= is not the same as ==
if (Volume == 0) Serial.println("zero");
if (Volume == 1) Serial.println("one");
That works, thanks. I need to go back and study why a Boolean operator is needed for comparing integer values.
cmiyc
4
alex04032:
It's not a Boolean operator.
= is an assignment operator.
== is a comparison operator.
So in order to do a comparison, you need to use the comparison operator.
Clarity. Thank you so much.
and "Volume == 1" is a boolean expression (may caused the confusion
