I'm working on my very first project, which is creating a custom pcb for an led chaser. However this project dimensions are really small: 45mm lenght and 8 mm width,
I have to place 6 RGB LED SMD, 2 LED SMD, a microcontroller which is yet to be determined, and the resistors for each led.
My question is: can I use 0603 resistors for 1203 led smd ?
Some (all?) LEDs may share a single resistor - maybe you need to use some PWM tricks to make the brightness equal.
In some circumstances you need no resistor at all.
