Hello, for a project of mine I need to output a 1.02 Mhz clock signal on Arduino Mega.
I have been able to generate a 1.0 Mhz clock with timer 4, but is it possible to get any closer to 1.02 Mhz? Maybe combining two clocks?
Edit: this code i wrote for 1 Mhz
TCCR4A = _BV(COM4B1) | _BV(WGM41) | _BV(WGM40);
TCCR4B = _BV(WGM43) | _BV(WGM42) | _BV(CS41); // prescaler = 8
// Set the output compare register for Timer 4
OCR4A = 1;
Try with
https://www.arduinoslovakia.eu/application/timer-calculator
Add: It looks like the closest value you can get is 1.066 MHz.
This should get 1.23 MHz with an 8 bit timer on the UNO (16MHz crystal driven)
If your Mega has a 8 bit timer you could see if you can set it similar.
* URL: https://dbuezas.github.io/arduino-web-timers/#mcu=ATMEGA328P&timer=0&timerMode=FPWM&topValue=OCR0A&OCR0A=11
* Mode : FPWM
* Period : 812.5 ns
* Frequency: 1.23077 MHz
* Outputs : none
void setup(){
noInterrupts();
TCCR0A =
1 << WGM01 |
1 << WGM00;
TCCR0B =
1 << WGM02 |
1 << CS00;
OCR0A = 12;
interrupts();
system
Closed
4
