1/4 microstep works, but full step will not
Hello all, I am using a NEMA14 in conjugation with a DRV8825 driver and a 9V power supply. The code below runs perfectly fine when I set the microstepping to a 1/4. However when I change to a full step the motor just buzzes and doesn't move. I have posted my code below, thanks in advance!
#include <AccelStepper.h>
int enPin = 8;
AccelStepper stepper(AccelStepper::DRIVER, 2, 4);
    pinMode( enPin ,OUTPUT);
  //digitalWrite( enPin , HIGH); // Deactivates Motor
   digitalWrite( enPin , LOW); // Activates Motor
stepper.setMaxSpeed(4000);
stepper.setSpeed(800);
  stepper.moveTo(-8000); //need 85663 steps to travel whole rail 340mm length, 0.003969mm/step
  stepper.runSpeedToPosition();
  stepper.moveTo(160000); //need 85663 steps to travel whole rail 340mm length, 0.003969mm/step
Very common problem. Try stepping slower. Basically the stepper cant accelerate fast enough and just stalls.
How would you go about doing that? When I add in myStepper.setAcceleration() I can hear the motor speeding up but there is no movement from the screw
You forgot to set the acceleration!
NEMA14 is a mechanical specification, not electrical. 9 volt supply make me nervous. Tell more, closer data, please.
I think this could be a programming problem. There is no big issue but I see a few small things that could be confusing the motor. In setup, only set maxSpeed. In loop, moveTo sets target, but you don't need to run to position twice. Do something like .moveTo(-8000) then setSpeed(800) then only call runSpeedToPosition at the very end. You can still stop the motor at specific spots by using the function if (distanceToGo() == 0) -> do whatever. Then you can set new target position with moveTo and new speed.
I made a project similar to this with a robotic arm controlled with constant speed to positions. the repo is here, feel free to reference it. No need to set acceleration either if you plan to only use constant speed. https://github.com/RoboticWorx/ERA-Chess-Robot/blob/main/ERA_Chess
I tried setting the speed to "stepper.setSpeed(200)" the motor still just buzzes without rotating the lead screw (full step configuration). But if I change to a 1/4 step it moves the screw
If I provided additional amperage would this prevent the stall?
It might help, but more volts would also help. Slow the stepping right down to check it full steps slowly.
