1-5V 20A adjustable power supply
I'm wanting to find, or build, a power supply that can supply up to 20A at 5V but is also adjustable from 1-5V.
I haven't managed to find anything off-the-shelf that can do this. I have found a board that can supply 20A at 5V and my initial think was to then build a circuit with an adjustable voltage regulator.
Here is the PSU:
I'm looking for any advice on how to make this work, the voltage can either be adjusted with a pot or a voltage signal.
Thanks in advance!
For high current a voltage regulator chip that drives an external pass transistor would be needed,
but here the voltage is v. small and current really high - bit of a problem as a Darlington pass
transistor would waste too much voltage and an NPN capable of 20A is going to have low gain.
I think a variable output SMPS would be much to be prefered if it can be found.
I'd be willing to bet that these guys could custom build something for you:
Just realize that what you are asking for is a bit special, and will likely cost a pretty penny (whether you can find it off the shelf, or custom designed).
Thanks for your help,
Finally managed to find a bench PSU that matches the spec I need:
http://www.ebay.co.uk/itm/30V-20A-LED-High-Power-Switching-Variable-DC-Power-Supply-220V-New-/261179472046?pt=UK_BOI_Electrical_Test_Measurement_Equipment_ET&hash=item3ccf8278ae
Would still prefer to have a smaller unit that I could integrate into my device and hook a pot up too myself but this might do. It has constant current control which is a plus.
Next step is to build an H-bridge board to flip the polarity of the supply. My initial thought was to use one of these:
http://www.ficrelay.com.hk/details/FRA9T.pdf, just a DPDT relay that I'll control from a separate supply (probably 24v or 12v). Is it as simple as this or is there anything else I should be thinking about?
