Laptop of Windows 7 Pro and Arduino 1.6.5 - works great.
Work computer Windows 7 Pro and Arduino 1.6.5 -- problems.
The install works fine, but when I launch, the splash screen would come up (Loading Config...) and then disappear.
I read that I should try: arduino_debug.exe
I got the following....
arduino_debug.exe
Loading configuration...
java.lang.ArrayIndexOutOfBoundsException: 3
at processing.app.windows.RegQueryParser.parse(RegQueryParser.java:29)
at processing.app.windows.RegQueryParser.(RegQueryParser.java:14)
at processing.app.windows.Platform.getFolderPathFromRegistry(Platform.ja
va:71)
at processing.app.windows.Platform.recoverSettingsFolderPath(Platform.ja
va:55)
at processing.app.windows.Platform.init(Platform.java:50)
at processing.app.Base.guardedMain(Base.java:148)
at processing.app.Base.main(Base.java:132)
I watched task manager to see that javaw.exe would start and quickly die.
So, I uninstalled the IDE and reinstalled. Same result.
I uninstalled java and reinstalled (both 32 and 64 bit) - Same result both ways.
I tried uninstalling both, rebooting, reinstalling, rebooting, and trying. Also tried a couple of prior IDE versions with same result.
I removed spyware and virus protecting thinking it might be blocking javaw (even though I was able to confirm other java apps worked.
Now, arduino-debug.exe gave me the following error:
org.apache.commons.exec.ExecuteException: Process exited with an error: 1 (Exit value: 1)
at org.apache.commons.exec.DefaultExecutor.executeInternal(DefaultExecutor.java:377)
at org.apache.commons.exec.DefaultExecutor.execute(DefaultExecutor.java:160)
at org.apache.commons.exec.DefaultExecutor.execute(DefaultExecutor.java:147)
at processing.app.windows.Platform.getFolderPathFromRegistry(Platform.java:70)
at processing.app.windows.Platform.recoverDefaultSketchbookFolder(Platform.java:60)
at processing.app.windows.Platform.init(Platform.java:51)
at processing.app.Base.guardedMain(Base.java:153)
at processing.app.Base.main(Base.java:137)
I AM the administrator at work. So, I have admin rights; however, I did try 1.6.5 with the installer and the zip download. Same results. Keep in mind, install went perfect. It simply doesn't complete the launching as it gets stuck at Loading configuration.
Never having an issue with any other software, I was stumped.
Other testing:
(confirmed it is not the machine and the user rights)
Logged in as administrator - IDE works.
Logged in as another user - IDE works.
Logged in on another machine as my profile (profile gets created on new machine) - IDE works
So, it was specific to my machine with my profile.
Resolution:
I had to delete my profile (actually moved/renamed it in c:\users\profile ), logged into machine as me (creates same name profile), then copy everything from the old (moved) profile. Now everything works and I retained everything from my old profile.
