Problems with 1.6.7 on Linux Mint 15, I hope this is an OK place to post this.
Everything goes fine then it goes bonkers. I can compile but it cannot upload the code. These are known good sketches. The problem has occurred on 4 different uno's and one mega2650 with different sketches. The errors i typically get are as follows:
Sketch uses 24,642 bytes (9%) of program storage space. Maximum is 253,952 bytes.
Global variables use 5,051 bytes (61%) of dynamic memory, leaving 3,141 bytes for local variables. Maximum is 8,192 bytes.
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
In most cases the serial monitor is still operating. The messages from the above sketch are confusing to me. The sketch is working without any problems including the serial monitor. The first time I compiled it all went well and worked. The second time through 38th I get the above errors. I have power cycled several times, changed usb ports etc. The board selected etc is correct. In earlier versions this was never a problem, the serial was rock solid.
Also if I have a backup copy "sketchnam(160321).ino it will automatically insert it into the sketchmane.ino file when compiling and I get tons of duplicate errors.
There are other problems with 1.6.7 on min715 but these are the ones currently bothering me.
Thanks
