1.8.4 Error uploading sketch avrdude programmer not responding
I am working on windows 8.1 and I am trying to work on a project, but randomly I couldn't program anymore. I have two arduino pro mini's and both are failing to upload the sketch. I have disable/enable the COM port as well as trying an example sketch, but nothing has worked. The weird part is that I can open the serial monitor and see where my old code was outputting data, so I know communication is working. I enabled verbose output during upload and the following is what I see:
Arduino: 1.8.4 (Windows 8.1), Board: "Arduino Pro or Pro Mini, ATmega168 (3.3V, 8 MHz)"
Archiving built core (caching) in: C:\Users\pxb07\AppData\Local\Temp\arduino_cache_814882\core\core_arduino_avr_pro_cpu_8MHzatmega168_0c812875ac70eb4a9b385d8fb077f54c.a
Sketch uses 3284 bytes (22%) of program storage space. Maximum is 14336 bytes.
Global variables use 335 bytes (32%) of dynamic memory, leaving 689 bytes for local variables. Maximum is 1024 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega168 -carduino -PCOM8 -b19200 -D -Uflash:w:C:\Users\pxb07\AppData\Local\Temp\arduino_build_381498/SoftwareSerialExample.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM8
         Using Programmer              : arduino
         Overriding Baud Rate          : 19200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x28
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x28
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x28
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x28
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x28
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x28
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x28
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x28
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x28
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x28
avrdude done.  Thank you.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
Have you tried an older IDE version , May it helps
Could you explain what you mean by "I have disable/enable the COM port" in more detail please.
If you blindly change COM ports or disable them in device manager there are quite a few issues that can occur.
In such cases it is better to reset the com port stack for all your com ports except COM 1 which is windows default port.
When doing so ensure nothing else is plugged in that wants to use a com port as that can mess with the com reset.
The common method is shown here and works for most flavours of windows.
Did you find a solution cause I am stuck at the same place
