1.8.5 An error occurred while uploading the sketch
I am new to Arduino. I have installed v1.8.5.
While uploading I am getting error : "An error occurred while uploading the sketch". I have set the flag for verbose output and this is all that I am getting. Before this error message, following appears in the RED. Not sure if it has any significance.
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
I am starting the IDE first and then opening the sketch.
Please help.
please give us more detail on which board you are using. it seems to have a too high baud rate (read your error output)
I am using Arduino Uno R3 board. It is using Microcontroller ATmega328P.
Please do this:
  • File > Preferences > Show verbose output during: > compilation (uncheck) > upload (check) > OK
  • Sketch > Upload
  • After the upload fails you'll see a button on the right side of the orange bar "Copy error messages". Click that button.
  • Paste the error messages in a reply here USING CODE TAGS (</> button on the toolbar).
I have the same problem, but I use arduino mega 2560 ..
the error is:
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Sketch uses 3288 bytes (1%) of program storage space. Maximum is 253952 bytes.
Global variables use 198 bytes (2%) of dynamic memory, leaving 7994 bytes for local variables. Maximum is 8192 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega2560 -cwiring -PCOM4 -b115200 -D -Uflash:w:C:\Users\Mervat\AppData\Local\Temp\arduino_build_828552/mywave.ino.hex:i
Using Port : COM4
Using Programmer : wiring
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude done. Thank you.
option enabled in File -> Preferences.
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM1 -b115200 -D -Uflash:w:C:\Users\sohel\AppData\Local\Temp\arduino_build_136177/sketch_apr19b.ino.hex:i
Using Port : COM1
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xab
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xab
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xab
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xab
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xab
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xab
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xab
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xab
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xab
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xab
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Arduino: 1.8.8 (Windows Store 1.8.19.0) (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Sketch uses 31652 bytes (12%) of program storage space. Maximum is 253952 bytes.
Global variables use 2259 bytes (27%) of dynamic memory, leaving 5933 bytes for local variables. Maximum is 8192 bytes.
C:\Users\shikr\OneDrive\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino14/bin/avrdude -CC:\Users\shikr\OneDrive\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino14/etc/avrdude.conf -v -patmega2560 -cwiring -PCOM3 -b115200 -D -Uflash:w:C:\Users\shikr\AppData\Local\Temp\arduino_build_598433/hoho.ino.hex:i
avrdude: Version 6.3-20171130
System wide configuration file is "C:\Users\shikr\OneDrive\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino14/etc/avrdude.conf"
Using Port : COM3
Remove any connections to pins 0 and 1. These pins are used for communication with your computer, including uploads. Connecting anything to these pins can interfere with uploads.
Make sure you have selected the port of your Arduino board from the Tools > Port menu.
Sometimes the port will be labeled with the board name in the menu. Other times it will not. If you don’t know which port is your Arduino, you can find it like this:
  • Unplug your Arduino board from the computer.
  • Tools > Port
  • Note the ports, if any, listed in the menu.
  • Close the Tools menu
  • Plug your Arduino board into the computer.
  • Tools > Port - The new port listed in the menu is your Arduino board.
If the Tools > Port menu is grayed or the port of your Arduino does not appear on the menu:
  • Make sure your USB cable is fully inserted into the Arduino board and the computer.
  • You may need to install the driver for the USB-serial chip on your Arduino.
  • You may be using a charge-only or defective USB cable. Try a different cable or test your cable on another device to confirm that it works for data.
  • Using a USB 3.0 port on your computer may cause problems. Try a USB 2.0 port.
