1.8 TFT LCD HELP
Hello all i just got a new tft lcd from ebay http://www.ebay.com/itm/1-8-inch-tft-lcd-shield-w-TF-Card-Reader-for-arduino-/270972138102?pt=BI_Electrical_Equipment_Tools&hash=item3f1732b276
not having much luck with text on the lcd it comes on upside down and back to front and bmp files work ok
This is the code that i download for it and put in the text part of the code
#include <ST7735.h>
#include <SD.h>
#include <SPI.h>
// If we are using the hardware SPI interface, these are the pins (for future ref)
#define sclk 13    //Hardware SPI SCLK
#define mosi 11    //Hardware SPI MOSI
// You can just connect the reset pin to +5V to generate a hardware reset
// Uncomment follow line to use software reset
#define rst 8
// these pins are required
#define cs 10      //LCD Chipselect
#define dc 9       //LCD Data or Command
#define bkl 2      //LCD Black Light
// Color definitions
#define	BLACK           0x0000
#define	BLUE            0x001F
#define	RED             0xF800
#define	GREEN           0x07E0
#define CYAN            0x07FF
#define MAGENTA         0xF81F
#define YELLOW          0xFFE0
#define WHITE           0xFFFF
// to draw images from the SD card, we will share the hardware SPI interface
ST7735 tft = ST7735(cs, dc, rst);
// For Arduino Uno/Duemilanove, etc
//  connect the SD card with MOSI going to pin 11, MISO going to pin 12 and SCK going to pin 13 (standard)
//  Then pin 4 goes to CS (or whatever you have set up)
#define SD_CS 4    // Set the chip select line to whatever you use (4 doesnt conflict with the library)
// the file itself
File bmpFile;
// information we extract about the bitmap file
int bmpWidth, bmpHeight;
uint8_t bmpDepth, bmpImageoffset;
// Key scan informations
int sensorValue;        // Hold the analog pin vaule
int sensorPin = A0;    // select the input pin for the potentiometer
void setup(void) {
  pinMode(cs, OUTPUT);
  digitalWrite(cs, HIGH);
  //Open the backlight
  pinMode(bkl, OUTPUT);
  digitalWrite(bkl, LOW);
  // initialize a ST7735R TFT
  tft.initR();      // change this to initB() for ST7735B TFT's
  // Just do a simple test
  tft.writecommand(ST7735_DISPON);
  uint16_t time = millis();
  tft.fillScreen(BLACK);
  time = millis() - time;
  Serial.print("Initializing SD card...");
  if (!SD.begin(SD_CS)) {
    Serial.println("failed!");
    return;
  Serial.println("SD OK!");
  bmpFile = SD.open("p0.bmp");
  if (! bmpFile) {
    Serial.println("didnt find image");
    while (1);
  if (! bmpReadHeader(bmpFile)) {
     Serial.println("bad bmp");
     return;
  Serial.print("image size ");
  Serial.print(bmpWidth, DEC);
  Serial.print(", ");
  Serial.println(bmpHeight, DEC);
  bmpdraw(bmpFile, 0, 0);
  delay(5000);
  tft.drawString (10, 10, "on", RED);
  tft.drawString (10, 20, "Temperature", GREEN);
  tft.drawString (10, 30, "Humidity", GREEN);
  tft.drawString (80, 130, "HELLO", YELLOW);
  sensorValue = analogRead(sensorPin);
  if(sensorValue <= 10)
     Serial.println("Up pressed");
  if(sensorValue <= 523 && sensorValue > 503)
     Serial.println("Down pressed");
  if(sensorValue <= 694 && sensorValue > 674)
     Serial.println("Left pressed");
  if(sensorValue <= 779 && sensorValue > 759)
     Serial.println("Right pressed");
  if(sensorValue <= 830 && sensorValue > 810)
     Serial.println("OK pressed");
  if(sensorValue <= 865 && sensorValue > 845)
     Serial.println("Cancel pressed");
void testfastlines(uint16_t color1, uint16_t color2) {
   for (uint16_t y=0; y < tft.height; y+=5) {
     tft.drawHorizontalLine(0, y, tft.width, color1);
   for (uint16_t x=0; x < tft.width; x+=5) {
     tft.drawVerticalLine(x, 0, tft.height, color2);
// This procedure reads a bitmap and draws it to the screen
// its sped up by reading many pixels worth of data at a time
// instead of just one pixel at a time. increading the buffer takes
// more RAM but makes the drawing a little faster. 20 pixels' worth
// is probably a good place
#define BUFFPIXEL 20
void bmpdraw(File f, int x, int y) {
  bmpFile.seek(bmpImageoffset);
  uint32_t time = millis();
  uint16_t p;
  uint8_t g, b;
  int i, j;
  uint8_t sdbuffer[3 * BUFFPIXEL];  // 3 * pixels to buffer
  uint8_t buffidx = 3*BUFFPIXEL;
  //Serial.print("rotation = "); Serial.println(tft.getRotation(), DEC);
  //set up the 'display window'
  tft.setAddrWindow(x, y, x+bmpWidth-1, y+bmpHeight-1);
  uint8_t rotback = tft.getRotation();
  for (i=0; i< bmpHeight; i++) {
    // bitmaps are stored with the BOTTOM line first so we have to move 'up'
    for (j=0; j<bmpWidth; j++) {
      // read more pixels
      if (buffidx >= 3*BUFFPIXEL) {
        bmpFile.read(sdbuffer, 3*BUFFPIXEL);
        buffidx = 0;
      // convert pixel from 888 to 565
      b = sdbuffer[buffidx++];     // blue
      g = sdbuffer[buffidx++];     // green
      p = sdbuffer[buffidx++];     // red
      p >>= 3;
      p <<= 6;
      g >>= 2;
      p |= g;
      p <<= 5;
      b >>= 3;
      p |= b;
     //Serial.print(p, HEX);
      // write out the 16 bits of color
      //tft.drawPixel(i, j, p);
      tft.pushColor(p);
  Serial.print(millis() - time, DEC);
  Serial.println(" ms");
boolean bmpReadHeader(File f) {
   // read header
  uint32_t tmp;
  if (read16(f) != 0x4D42) {
    // magic bytes missing
    return false;
  // read file size
  tmp = read32(f);
  Serial.print("size 0x"); Serial.println(tmp, HEX);
  // read and ignore creator bytes
  read32(f);
  bmpImageoffset = read32(f);
  Serial.print("offset "); Serial.println(bmpImageoffset, DEC);
  // read DIB header
  tmp = read32(f);
  Serial.print("header size "); Serial.println(tmp, DEC);
  bmpWidth = read32(f);
  bmpHeight = read32(f);
  if (read16(f) != 1)
    return false;
  bmpDepth = read16(f);
  Serial.print("bitdepth "); Serial.println(bmpDepth, DEC);
  if (read32(f) != 0) {
    // compression not supported!
    return false;
  Serial.print("compression "); Serial.println(tmp, DEC);
  return true;
// These read data from the SD card file and convert them to big endian
// (the data is stored in little endian format!)
// LITTLE ENDIAN!
uint16_t read16(File f) {
  uint16_t d;
  uint8_t b;
  b = f.read();
  d = f.read();
  d <<= 8;
  d |= b;
  return d;
// LITTLE ENDIAN!
uint32_t read32(File f) {
  uint32_t d;
  uint16_t b;
  b = read16(f);
  d = read16(f);
  d <<= 16;
  d |= b;
  return d;
I also tryed this code from adafruit also the text is upside down
// You can use any (4 or) 5 pins
#define sclk 13
#define mosi 11
#define cs 10
#define dc 9
#define rst 8  // you can also connect this to the Arduino reset
#define	BLUE            0x001F
#define	RED             0xF800
#define CYAN            0x07FF
#include <ST7735.h>
#include <SPI.h>
// Option 1: use any pins but a little slower
// Option 2: must use the hardware SPI pins
// (for UNO thats sclk = 13 and sid = 11) and pin 10 must be
// an output. This is much faster - also required if you want
// to use the microSD card (see the image drawing example)
//ST7735 tft = ST7735(cs, dc, rst);
void fillpixelbypixel(uint16_t color) {
  for (uint8_t x=0; x < tft.width; x++) {
    for (uint8_t y=0; y < tft.height; y++) {
      tft.drawPixel(x, y, color);
  delay(100);
void setup(void) {
  Serial.print("hello!");
  tft.initR();               // initialize a ST7735R chip
  Serial.println("init");
  Serial.println(time, DEC);
  testdrawtext("Hello ", WHITE);
  delay(5000);
  //a single pixel
  tft.drawPixel(tft.width/2, tft.height/2, GREEN);
  // line draw test
  testlines(YELLOW);
  // optimized lines
  testfastlines(RED, BLUE);
  testdrawrects(GREEN);
  testfillrects(YELLOW, MAGENTA);
  testfillcircles(10, BLUE);
  testdrawcircles(10, WHITE);
  Serial.println("done");
  tft.writecommand(ST7735_INVON);
  tft.writecommand(ST7735_INVOFF);
void testlines(uint16_t color) {
   for (uint16_t x=0; x < tft.width; x+=6) {
     tft.drawLine(0, 0, x, tft.height-1, color);
   for (uint16_t y=0; y < tft.height; y+=6) {
     tft.drawLine(0, 0, tft.width-1, y, color);
     tft.drawLine(tft.width-1, 0, x, tft.height-1, color);
     tft.drawLine(tft.width-1, 0, 0, y, color);
     tft.drawLine(0, tft.height-1, x, 0, color);
     tft.drawLine(0, tft.height-1, tft.width-1, y, color);
     tft.drawLine(tft.width-1, tft.height-1, x, 0, color);
     tft.drawLine(tft.width-1, tft.height-1, 0, y, color);
void testdrawtext(char *text, uint16_t color) {
  tft.drawString(0, 0, text, color);
void testdrawrects(uint16_t color) {
   tft.drawRect(tft.width/2 -x/2, tft.height/2 -x/2 , x, x, color);
void testfillrects(uint16_t color1, uint16_t color2) {
 for (uint16_t x=tft.width-1; x > 6; x-=6) {
   tft.fillRect(tft.width/2 -x/2, tft.height/2 -x/2 , x, x, color1);
   tft.drawRect(tft.width/2 -x/2, tft.height/2 -x/2 , x, x, color2);
void testfillcircles(uint8_t radius, uint16_t color) {
  for (uint8_t x=radius; x < tft.width; x+=radius*2) {
    for (uint8_t y=radius; y < tft.height; y+=radius*2) {
      tft.fillCircle(x, y, radius, color);
void testdrawcircles(uint8_t radius, uint16_t color) {
  for (uint8_t x=0; x < tft.width+radius; x+=radius*2) {
    for (uint8_t y=0; y < tft.height+radius; y+=radius*2) {
      tft.drawCircle(x, y, radius, color);
this is realy bugging me there is not much on these tft lcd and they are realy nice lcds
I bought the Adafruit 1.8" tft lcd and it was perfect with the sketch and library supplied. I was able to combine the functions in the sketch and libraries with a GPS program to Perfectly display any text I desired... by reading the sketch carefully and applying the information found there.
This should fix your issues add it in the setup section or rotate the lcd 180 deg.
There is actually quite a lot of information on the tft but you need to read both the sketch you are using and the Rotation test sketch
to find all you will need.
tft.setRotation(tft.getRotation()+2); // This will find the current rotation value and increment it twice to flip the text... "Normal"
Your LCD board is rotated 180 deg from the adafriut LCD... on mine the pins are at the bottom.
tft.setCursor(X,Y) is column * pixel ,row * pixel, not by character... to position the cursor to second line second character you would need to write tft.setCursor(8,8);
Doc
