1.8 TFT SPI
Hi everyone
I just bought a 1.8 TFT LCD module for my arduino UNO from the following website (eBay)
Unfortunately making it work is a bit more difficult than I expected.
I do the following connections be twin module and UNO
MODULE ARDUINO UNO Pin
1 rst 8
2 CS 10
3 D/C 9
4 DIN 11 (default SPI MOSI)
5 CLK 13 (default SPI clock)
6 VCC +5 VOLTS
7 BL +3.3 VOLTS
8 GND GND
and then i'm uploading this sketch
#include <SPI.h>
#include <TFT.h>            // Arduino TFT library
#define cs   10
#define dc   9
#define rst  8
TFT screen = TFT(cs, dc, rst);
  // initialize the screen
  screen.begin();
  // make the background black
  screen.background(0,0,0);
  // set the text color to white
  screen.stroke(255,255,255);
  // write text to the screen in the top left corner
  screen.text("Testing!", 0, 0);
It was suppose to print "testing" on the top left corner but nothing happens, the screen does light because of the 3.3v
is there a problem with the TFT library? is it not compatible with this module?
do I need to change something in the header file? perhaps an address?
Please leave some thoughts
thanks in advance
I run this testprog:
  EKSEMPELPROGRAM - koples som tegnings vist i bildet på Itslearing og i teksten under
  (se: TFT-Display 1.8)
Dette displayet kan også bruke biblioteket "UTFT" av Henning Karlsen
Hennings bibl er mer omfattende og bruker mer minne.
Driverchip på 1.8"-displayet er ST7735R (må nevnes i HK's bibl)
Legg displayet slik som dette:
oGND  ->> gnd
oVCC  ->> 5V
oNC
oNC
oNC
oRESET->> 8
oA0   ->> 9 (pinne også omtalt som D/C)
oSDA  ->> 11
oSCK  ->> 13
oCS   ->> 10
oSCK  ->> (13)
oMISO ->> (12)
oMOSI ->> (11)
oCS   ->> (7)
oLED+ ->> 3.3V
oLED- ->> gnd
  This is an example sketch for the Adafruit 1.8" SPI display.
  This library works with the Adafruit 1.8" TFT Breakout w/SD card
  ----> http://www.adafruit.com/products/358
#define cs   10 // ChipSelect for displayet (SD-kortet Må bruke en annen ledig pin)
#define dc   9  // OBS på displayet merket A0
#define rst  8  // Reset kan også koples til Arduinos RST-pin
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library
#include <SPI.h>
Adafruit_ST7735 tft = Adafruit_ST7735(cs, dc, rst);
void setup(void)
  // Our supplier changed the 1.8" display slightly after Jan 10, 2012
  // so that the alignment of the TFT had to be shifted by a few pixels
  // this just means the init code is slightly different. Check the
  // color of the tab to see which init code to try. If the display is
  // cut off or has extra 'random' pixels on the top & left, try the
  // other option!
  // If you are seeing red and green color inversion, use Black Tab
  // If your TFT's plastic wrap has a Black Tab, use the following:
  tft.initR(INITR_BLACKTAB);   // initialize a ST7735S chip, black tab
  // If your TFT's plastic wrap has a Red Tab, use the following:
  // tft.initR(INITR_REDTAB);   // initialize a ST7735R chip, red tab
  // If your TFT's plastic wrap has a Green Tab, use the following:
  //tft.initR(INITR_GREENTAB); // initialize a ST7735R chip, green tab
{ // dette testprogrammet viser NOE av hva du kan få til.
  // utforsk mulighetene...
  tft.fillScreen(ST7735_MAGENTA);
  tft.setTextSize(2);
  tft.setCursor(3, 16);
  tft.setTextColor(0X8080);
  tft.println("GRATULERER");
  tft.setCursor(0,45);
  tft.setTextSize(1);
  tft.setTextColor(0XFFFF);
  tft.println("Nu kan du se koden ogfinne hva DU kan     bruke dette til...");
  // a single pixel
  tft.drawPixel(8,75,ST7735_GREEN);
  tft.drawLine(20, 70, 100, 88, ST7735_GREEN);
  tft.drawRect(20,90,25,25, 0X00); // TROR FARGE 0 ER SVART
  tft.drawRect(19,89,27,27, 0X00); // TROR FARGE 0 ER SVART
  tft.drawCircle(80, 100 , 10, ST7735_RED); // TROR FARGE 0 ER SVART
  tft.drawCircle(80, 100 , 11, ST7735_RED); // TROR FARGE 0 ER SVART
  tft.drawTriangle(60,100,100,130,110,80,ST7735_BLUE);
  tft.drawTriangle(61,101,101,131,111,81,ST7735_BLUE);
  delay(5000);
  tft.fillScreen(ST7735_WHITE);
  mediabuttons();
  delay(3000);
void testlines(uint16_t color) {
  tft.fillScreen(ST7735_BLACK);
  for (int16_t x=0; x < tft.width(); x+=6) {
    tft.drawLine(0, 0, x, tft.height()-1, color);
  for (int16_t y=0; y < tft.height(); y+=6) {
    tft.drawLine(0, 0, tft.width()-1, y, color);
    tft.drawLine(tft.width()-1, 0, x, tft.height()-1, color);
    tft.drawLine(tft.width()-1, 0, 0, y, color);
    tft.drawLine(0, tft.height()-1, x, 0, color);
    tft.drawLine(0, tft.height()-1, tft.width()-1, y, color);
    tft.drawLine(tft.width()-1, tft.height()-1, x, 0, color);
    tft.drawLine(tft.width()-1, tft.height()-1, 0, y, color);
void testdrawtext(char *text, uint16_t color) {
  tft.setCursor(0, 0);
  tft.setTextColor(color);
  tft.setTextWrap(true);
  tft.print(text);
void testfastlines(uint16_t color1, uint16_t color2) {
  for (int16_t y=0; y < tft.height(); y+=5) {
    tft.drawFastHLine(0, y, tft.width(), color1);
  for (int16_t x=0; x < tft.width(); x+=5) {
    tft.drawFastVLine(x, 0, tft.height(), color2);
void testdrawrects(uint16_t color) {
    tft.drawRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color);
void testfillrects(uint16_t color1, uint16_t color2) {
  for (int16_t x=tft.width()-1; x > 6; x-=6) {
    tft.fillRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color1);
    tft.drawRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color2);
void testfillcircles(uint8_t radius, uint16_t color) {
  for (int16_t x=radius; x < tft.width(); x+=radius*2) {
    for (int16_t y=radius; y < tft.height(); y+=radius*2) {
      tft.fillCircle(x, y, radius, color);
void testdrawcircles(uint8_t radius, uint16_t color) {
  for (int16_t x=0; x < tft.width()+radius; x+=radius*2) {
    for (int16_t y=0; y < tft.height()+radius; y+=radius*2) {
      tft.drawCircle(x, y, radius, color);
void testtriangles() {
  int color = 0xF800;
  int t;
  int w = 63;
  int x = 159;
  int y = 0;
  int z = 127;
  for(t = 0 ; t <= 15; t+=1) {
    tft.drawTriangle(w, y, y, x, z, x, color);
    x-=4;
    y+=4;
    z-=4;
    color+=100;
void testroundrects() {
  int color = 100;
  int i;
  int t;
  for(t = 0 ; t <= 4; t+=1) {
    int x = 0;
    int y = 0;
    int w = 127;
    int h = 159;
    for(i = 0 ; i <= 24; i+=1) {
      tft.drawRoundRect(x, y, w, h, 5, color);
      x+=2;
      y+=3;
      w-=4;
      h-=6;
      color+=1100;
    color+=100;
void tftPrintTest() {
  tft.setTextWrap(false);
  tft.setCursor(0, 30);
  tft.setTextColor(ST7735_RED);
  tft.setTextSize(1);
  tft.println("Hello World!");
  tft.setTextColor(ST7735_YELLOW);
  tft.setTextSize(2);
  tft.setTextColor(ST7735_GREEN);
  tft.setTextSize(3);
  tft.setTextColor(ST7735_BLUE);
  tft.setTextSize(4);
  tft.print(1234.567);
  delay(1500);
  tft.setTextColor(ST7735_WHITE);
  tft.setTextSize(0);
  tft.setTextSize(1);
  tft.print(3.141592653, 6);
  tft.println(" Want pi?");
  tft.println(" ");
  tft.print(8675309, HEX); // print 8,675,309 out in HEX!
  tft.println(" Print HEX!");
  tft.println(" ");
  tft.println("Sketch has been");
  tft.println("running for: ");
  tft.setTextColor(ST7735_MAGENTA);
  tft.print(millis() / 1000);
  tft.print(" seconds.");
void mediabuttons() {
  // play
  tft.fillRoundRect(25, 10, 78, 60, 8, ST7735_WHITE);
  tft.fillTriangle(42, 20, 42, 60, 90, 40, ST7735_RED);
  // pause
  tft.fillRoundRect(25, 90, 78, 60, 8, ST7735_WHITE);
  tft.fillRoundRect(39, 98, 20, 45, 5, ST7735_GREEN);
  tft.fillRoundRect(69, 98, 20, 45, 5, ST7735_GREEN);
  // play color
  tft.fillTriangle(42, 20, 42, 60, 90, 40, ST7735_BLUE);
  delay(50);
  // pause color
  tft.fillRoundRect(39, 98, 20, 45, 5, ST7735_RED);
  tft.fillRoundRect(69, 98, 20, 45, 5, ST7735_RED);
  // play color
  tft.fillTriangle(42, 20, 42, 60, 90, 40, ST7735_GREEN);
Ok, this took a bit of time and reading through a lot of things but I have this working (as I am sure a few others have) for this specific board.
You do need to use the modified QDTECH library and the Adafruit libraries installed but the below is what I have working for SD card access which was the hardest part for me.
Did this with the lcd you listed in the ebay link and an Arduino Mini pro 3.3v
Let me know if this works.
Ryan
  as well as Adafruit raw 1.8" TFT display
  ----> http://www.adafruit.com/products/618
  Check out the links above for our tutorials and wiring diagrams
  These displays use SPI to communicate, 4 or 5 pins are required to
  interface (RST is optional)
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  MIT license, all text above must be included in any redistribution
 // FROM ARDUINO TO LCD PINS:
 //    6-6
 //    7-14
 //    8-7
 //    9-10
 //    11-8
 //    12-12
 //    13-9
 // ON LCD ONLY:
 //    13-8
 //    9-11
#include <Adafruit_QDTech.h> // Hardware-specific library
#include <SPI.h>
#include <SD.h>
#if defined(__SAM3X8E__)
    #undef __FlashStringHelper::F(string_literal)
    #define F(string_literal) string_literal
#endif
// TFT display and SD card will share the hardware SPI interface.
// Hardware SPI pins are specific to the Arduino board type and
// cannot be remapped to alternate pins.  For Arduino Uno,
// Duemilanove, etc., pin 11 = MOSI, pin 12 = MISO, pin 13 = SCK.
#define SD_CS    7  // Chip select line for SD card
#define TFT_CS  9  // Chip select line for TFT display
#define TFT_DC   8  // Data/command line for TFT
#define TFT_RST  6  // Reset line for TFT (or connect to +5V)
//Use these pins for the shield!
//#define TFT_CS   10
//#define TFT_DC   8
//#define TFT_RST  0  // you can also connect this to the Arduino reset
Adafruit_QDTech tft = Adafruit_QDTech(TFT_CS, TFT_DC, TFT_RST);
void setup(void) {
  // other option!
  tft.init();   // initialize a ST7735S chip, black tab
  //tft.initR(INITR_REDTAB);   // initialize a ST7735R chip, red tab
  Serial.print("Initializing SD card...");
  if (!SD.begin(SD_CS)) {
    Serial.println("failed!");
    return;
  Serial.println("OK!");
  bmpDraw("parrot.bmp", 0, 0);
// This function opens a Windows Bitmap (BMP) file and
// displays it at the given coordinates.  It's sped up
// by reading many pixels worth of data at a time
// (rather than pixel by pixel).  Increasing the buffer
// size takes more of the Arduino's precious RAM but
// makes loading a little faster.  20 pixels seems a
// good balance.
#define BUFFPIXEL 20
void bmpDraw(char *filename, uint8_t x, uint8_t y) {
  File     bmpFile;
  int      bmpWidth, bmpHeight;   // W+H in pixels
  uint8_t  bmpDepth;              // Bit depth (currently must be 24)
  uint32_t bmpImageoffset;        // Start of image data in file
  uint32_t rowSize;               // Not always = bmpWidth; may have padding
  uint8_t  sdbuffer[3*BUFFPIXEL]; // pixel buffer (R+G+B per pixel)
  uint8_t  buffidx = sizeof(sdbuffer); // Current position in sdbuffer
  boolean  goodBmp = false;       // Set to true on valid header parse
  boolean  flip    = true;        // BMP is stored bottom-to-top
  int      w, h, row, col;
  uint8_t  r, g, b;
  uint32_t pos = 0, startTime = millis();
  if((x >= tft.width()) || (y >= tft.height())) return;
  Serial.print("Loading image '");
  Serial.print(filename);
  Serial.println('\'');
  // Open requested file on SD card
  if ((bmpFile = SD.open(filename)) == NULL) {
    Serial.print("File not found");
    return;
  // Parse BMP header
  if(read16(bmpFile) == 0x4D42) { // BMP signature
    Serial.print("File size: "); Serial.println(read32(bmpFile));
    (void)read32(bmpFile); // Read & ignore creator bytes
    bmpImageoffset = read32(bmpFile); // Start of image data
    Serial.print("Image Offset: "); Serial.println(bmpImageoffset, DEC);
    // Read DIB header
    Serial.print("Header size: "); Serial.println(read32(bmpFile));
    bmpWidth  = read32(bmpFile);
    bmpHeight = read32(bmpFile);
    if(read16(bmpFile) == 1) { // # planes -- must be '1'
      bmpDepth = read16(bmpFile); // bits per pixel
      Serial.print("Bit Depth: "); Serial.println(bmpDepth);
      if((bmpDepth == 24) && (read32(bmpFile) == 0)) { // 0 = uncompressed
        goodBmp = true; // Supported BMP format -- proceed!
        Serial.print("Image size: ");
        Serial.print(bmpWidth);
        Serial.print('x');
        Serial.println(bmpHeight);
        // BMP rows are padded (if needed) to 4-byte boundary
        rowSize = (bmpWidth * 3 + 3) & ~3;
        // If bmpHeight is negative, image is in top-down order.
        // This is not canon but has been observed in the wild.
        if(bmpHeight < 0) {
          bmpHeight = -bmpHeight;
          flip      = false;
        // Crop area to be loaded
        w = bmpWidth;
        h = bmpHeight;
        if((x+w-1) >= tft.width())  w = tft.width()  - x;
        if((y+h-1) >= tft.height()) h = tft.height() - y;
        // Set TFT address window to clipped image bounds
        tft.setAddrWindow(x, y, x+w-1, y+h-1);
        for (row=0; row<h; row++) { // For each scanline...
          // Seek to start of scan line.  It might seem labor-
          // intensive to be doing this on every line, but this
          // method covers a lot of gritty details like cropping
          // and scanline padding.  Also, the seek only takes
          // place if the file position actually needs to change
          // (avoids a lot of cluster math in SD library).
          if(flip) // Bitmap is stored bottom-to-top order (normal BMP)
            pos = bmpImageoffset + (bmpHeight - 1 - row) * rowSize;
          else     // Bitmap is stored top-to-bottom
            pos = bmpImageoffset + row * rowSize;
          if(bmpFile.position() != pos) { // Need seek?
            bmpFile.seek(pos);
            buffidx = sizeof(sdbuffer); // Force buffer reload
          for (col=0; col<w; col++) { // For each pixel...
            // Time to read more pixel data?
            if (buffidx >= sizeof(sdbuffer)) { // Indeed
              bmpFile.read(sdbuffer, sizeof(sdbuffer));
              buffidx = 0; // Set index to beginning
            // Convert pixel from BMP to TFT format, push to display
            b = sdbuffer[buffidx++];
            g = sdbuffer[buffidx++];
            r = sdbuffer[buffidx++];
            tft.pushColor(tft.Color565(r,g,b));
          } // end pixel
        } // end scanline
        Serial.print("Loaded in ");
        Serial.print(millis() - startTime);
        Serial.println(" ms");
      } // end goodBmp
  bmpFile.close();
  if(!goodBmp) Serial.println("BMP format not recognized.");
// These read 16- and 32-bit types from the SD card file.
// BMP data is stored little-endian, Arduino is little-endian too.
// May need to reverse subscript order if porting elsewhere.
uint16_t read16(File f) {
  uint16_t result;
  ((uint8_t *)&result)[0] = f.read(); // LSB
  ((uint8_t *)&result)[1] = f.read(); // MSB
  return result;
uint32_t read32(File f) {
  uint32_t result;
  ((uint8_t *)&result)[2] = f.read();
  ((uint8_t *)&result)[3] = f.read(); // MSB
  return result;
