Hello everyone, I'm just curious if how can I connect 10 8-Digit 7-segment display modules on my 1 Arduino ATMega2560 and if that's even possible? It's supposed to display different values too. Like for example, I have 10 load cells, and each 7 segment display will also display those values per load cell. Please help? And if anyone here has any suggestions for me? Thank you so much in advance.
How many pins does a 7 segment display use? What is 10 times that number? Does the Mega have that many pins? It's not rocket science to answer your own question.
you can use I2C to add multiple lcd... It's possible
PaulS:
It's 10 pieces of 8-digit 7-segment display module. 7-segment display modules has 5 pins. VCC-GND-DIN-CS-CLK and I'm just asking what are the other suggestions you can share to display separate values on different modules using 1 ATmega.
