Hello everyone
I am new in using arduino and I need some help with my sketch. it wont let me out of the first loop meaning i cant get to the second mode using the button.
[sup]#include "OneButton.h"
int witheLEDPin1=2; //Declare whiteLEDPin1 an int, and set to pin 12
int witheLEDPin2=3; //Declare whiteLEDPin2 an int, and set to pin 13
int witheLEDPin3=4; //Declare whiteLEDPin1 an int, and set to pin 12
int witheOnTime1=125; //Declare witheOnTime1 an int.
int witheOffTime1=150; //Declare witheOffTime1 an int.
int witheOnTime2=250; //Declare witheOnTime2 an int.
int witheOffTime2=150; //Declare witheOffTime2 an int.
int witheOnTime3=125; //Declare witheOnTime3 an int.
int witheOffTime3=150; //Declare witheOffTime3 an int.
int numwithe1Blinks=7500; //Number of times to blink withe LED1
int numwithe2Blinks=0; //Number of times to blink withe LED2
int numwithe3Blinks=0; //Number of times to blink withe LED2
OneButton button1(A1, true); // Setup a new OneButton on pin A1.
void setup() { // setup code here, to run once:
Serial.begin(9600); // Setup the Serial port.
while (!Serial) { // wait for serial port to connect.
Serial.println("Starting 1Buttons...");
button1.attachClick(click1); // link the button 1 functions.
button1.attachDoubleClick(doubleclick1);
button1.attachLongPressStart(longPressStart1);
button1.attachLongPressStop(longPressStop1);
button1.attachDuringLongPress(longPress1);
pinMode(witheLEDPin1, OUTPUT); // Tell Arduino that witheLEDPin1 is an output pin
pinMode(witheLEDPin2, OUTPUT); // Tell Arduino that witheLEDPin2 is an output pin
pinMode(witheLEDPin3, OUTPUT); // Tell Arduino that witheLEDPin3 is an output pin
void loop() { // main code here, to run repeatedly:
button1.tick(); // keep watching the push buttons:
delay(100); // Wait
} // loop
// ----- button 1 callback functions
void click1() { // This function will be called when the button1 was pressed 1 time
Serial.println("Button 1 click.");
digitalWrite(witheLEDPin1,LOW);
digitalWrite(witheLEDPin2,LOW);
digitalWrite(witheLEDPin3,LOW);
for (int j=1; j<=numwithe1Blinks+numwithe2Blinks+numwithe3Blinks; j=j+1) { // Start our for loop
digitalWrite(witheLEDPin1,HIGH); //Turn white1 LED on
delay(witheOnTime1); //Leave on for whiteOnTime1
digitalWrite(witheLEDPin1,LOW); //Turn white1 LED off
delay(witheOffTime1); //Leave off for withe
digitalWrite(witheLEDPin2,HIGH); //Turn white2 LED on
delay(witheOnTime2); //Leave on for whiteOnTime2
digitalWrite(witheLEDPin2,LOW); //Turn white2 LED off
delay(witheOffTime2); //Leave off for withe
digitalWrite(witheLEDPin3,HIGH); //Turn white3 LED on
delay(witheOnTime3); //Leave on for whiteOnTime3
digitalWrite(witheLEDPin3,LOW); //Turn white3 LED off
delay(witheOffTime3); //Leave off for withe
} // click1
// This function will be called when the button1 was pressed 2 times in a short timeframe.
void doubleclick1() {
Serial.println("Button 1 doubleclick.");
} // doubleclick1
// This function will be called once, when the button1 is pressed for a long time.
void longPressStart1() {
Serial.println("Button 1 longPress start");
} // longPressStart1
// This function will be called often, while the button1 is pressed for a long time.
void longPress1() {
Serial.println("Button 1 longPress...");
} // longPress1
// This function will be called once, when the button1 is released after beeing pressed for a long time.
void longPressStop1() {
Serial.println("Button 1 longPress stop");
} // longPressStop1
// End
[/sup]
where im i going wrong
any advice would be greatly appreciated.
Thank you
