Hello, I was making a circuit diagram with Fritzing and im getting this notification that says "8 of 9 nets routed - 1 Connector still to be routed".
I found out that making a connection between 4xAAA VCC+ and the 9V VCC+ solves the problem but that doesn't seems right. Any advice?
Where did you get the idea that this is a Fritzing support forum?
Just a guess, The wire from the board VCC should no go to the aaa battery plus but to the arduino regulated output power.
Connecting 9v to 6v not a good idea to solve problem.
Cannot help with fritzing (sounds like a verb).
However one word of caution, the push in prototype boards are not very good with high currents.
You might consider wiring the servo's directly to the battery holder. You should also add some capacitors across the two V+ on the board. An off hand suggestion is 10µf and a 0.01µf across each.
It seems you don't have the grounds connected. That's generally a source of problems. Which doesn't negate the even greater source of problems of Fritzing itself (the unreadable diagrams, for starters - do learn to draw real schematics!).
