1 line Error
#include <DHT.h>
#include <Ethernet.h>
#include <SPI.h>
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0F, 0x4A, 0xB3 }; // RESERVED MAC ADDRESS
EthernetClient client;
#define DHTPIN 2 // SENSOR PIN
#define DHTTYPE DHT11 // SENSOR TYPE - THE ADAFRUIT LIBRARY OFFERS SUPPORT FOR MORE MODELS
DHT dht(DHTPIN, DHTTYPE);
long previousMillis = 0;
unsigned long currentMillis = 0;
long interval = 250000; // READING INTERVAL
int t = 0; // TEMPERATURE VAR
int h = 0; // HUMIDITY VAR
String data;
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
dht.begin();
delay(10000); // GIVE THE SENSOR SOME TIME TO START
h = (int) dht.readHumidity();
t = (int) dht.readTemperature();
data = "";
void loop(){
currentMillis = millis();
if(currentMillis - previousMillis > interval) { // READ ONLY ONCE PER INTERVAL
data = "temp1=" + t + "&hum1=" + h;
if (client.connect("www.*****..com",80)) { // REPLACE WITH YOUR SERVER ADDRESS
client.println("POST /add.php HTTP/1.1");
client.println("Host: *****.
.com"); // SERVER ADDRESS HERE TOO
client.println("Content-Type: application/x-www-form-urlencoded");
client.print("Content-Length: ");
client.println(data.length());
client.println();
client.print(data);
if (client.connected()) {
client.stop(); // DISCONNECT FROM THE SERVER
delay(2000); // WAIT FIVE MINUTES BEFORE SENDING AGAIN
above i got an error (highlighted in red)
exit status 1
invalid operands of types 'const char*' and 'const char [7]' to binary 'operator+'
Any kind souls out there to help me with that? Thanks in advance :slight_smile:
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks. Tom.. :slight_smile:
data is a String
t and h are ints
No wonder you can't concatenate them and put them in the String
which should i change?
You could turn t and h into Strings.
Or you could not use Strings at all.
And you could start using code tags.
