1 Wire multiple devices
Dear my friends,
I have being working on a 1 Wire network with multiple DS18S20 and a DS1994 for RTC timestamp.
The Question is: There is ant library for converting a timestamp to a standard time format?
Attached you will find my work in progress, some pieces of code taken from here and there.....
Thanks.
Oliveros
#include <OneWire.h>
OneWire  ds(10);  // on pin 10
byte onewireclock[8];       // Store 1 wire clock device code
//timedate td;                // Time - date structure
char dateLCD[9] = {""}; // Variables to send time and date to LCD
char timeLCD[9] = {""}; // Variables to send time and date to LCD
char text1[17];                // General LCD Text
void setup(void) {
  // initialize inputs/outputs
  // start serial port
void loop(void) {
  byte i;
  byte present = 0;
  byte data[12];
  byte addr[8];
  int Temp;
  if ( !ds.search(addr)) {
      //Serial.print("No more addresses.\n");
      ds.reset_search();
      return;
 // Serial.print("R=");  //R=28 Not sure what this is
  for( i = 0; i < 8; i++) {
//   Serial.print(addr[i], HEX); //Imprime el serial del dispositivo en reversa
  if ( OneWire::crc8( addr, 7) != addr[7]) {
      Serial.print("CRC is not valid!\n");
      return;
     // DS18S20 Temp Only Family Device
     if ( addr[0] == 0x28) {
        //Serial.print(" T=");//output the temperature to serial port
        GetTempS(addr);
        //Serial.print("C ");
      return;
        // DS1994 Family Device
        if (addr[0] == 0x04)
           Serial.println(GetTimeRTC(addr));
           return;
/*      if (addr[0] == 0x10)
           Serial.println(GetTemp(addr));
           return;
Serial.print("Device not supported.\n");
int GetTempS(byte* addr)
        byte i;
        byte j;
        int LowByte, HighByte, Temp, TReading, SignBit, Tc_100, Whole, Fract;
        byte data[12];
        byte dataj[12];
        byte present = 0;
        ds.reset();
        ds.select(addr);
        ds.write(0x44,1);         // start conversion, with parasite power on at the end
        delay(1000);     // maybe 750ms is enough, maybe not
        // we might do a ds.depower() here, but the reset will take care of it.
        ds.reset();
        ds.select(addr);
        //ds.write(0xCC);
        //  Serial.print("P=");
        //  Serial.print(present,HEX);
        //  Serial.print(" ");
        //for ( j = 0; j < 9; i++) {           // we need 9 bytes
        //    dataj[j] = ds.read();
            //      Serial.print(data[i], HEX);
            //LowByte = dataj[j];
        //ds.reset();
        //ds.select(addr);
        ds.write(0xBE);         // Read Scratchpad
        for ( i = 0; i < 9; i++) {           // we need 9 bytes
            data[i] = ds.read();
        //    LowByte = data[i];
        ds.reset();
        Temp=(data[1]<<8)+data[0];//take the two bytes from the response relating to temperature
        Tc_100 = (6 * Temp) + Temp / 4;
        Whole = Tc_100 / 100;
        Fract = Tc_100 % 100;
        if (SignBit) // If its negative
        Serial.print("-");
     Serial.print(Whole);
     Serial.print(".");
     if (Fract < 1)
      Fract = Fract * -1;
      //  Serial.print("0");
     Serial.print(Fract);
        Temp=Temp>>4;//divide by 16 to get pure celcius readout
        //next line is Fahrenheit conversion
        // Temp=Temp*1.8+32; // comment this line out to get celcius
        //Serial.print(Temp);
        return Temp;
int GetTemp(byte* addr)
        byte i;
        int Temp;
        byte data[12];
        byte present = 0;
        int temp;
        float ftemp;
        ds.reset();
        ds.select(addr);
        ds.write(0x44);         // start conversion, with parasite power on at the end
        ds.reset();
        ds.select(addr);
        temp = data[0];      // load all 8 bits of the LSB
         //get hi-rez data
           int cpc;  // count per deg C
           int cr = data[6];//data[7];  // Count Remain
           cpc = data[7]; //data[8];
          //   Serial.println(cr, HEX);
          //   Serial.println(cpc, HEX);
           if (cpc == 0)
              Serial.print("DS1920 BADTEMP");
          // According to data sheet, need to truncate 0.5C bit 0 from temperature data
          temp = temp >> 1;  // Shift one bit to drop bit 0 for following formula
          ftemp = temp - (float)0.25 + (cpc - cr)/(float)cpc;
          //end hi-rez data
          //ftemp = ((ftemp * 9) / 5.0) + 32; //C -> F   (F = (9/5)C + 32)
          itoa(int (ftemp), text1, 10); // convert int to string
        return ftemp;
// GetTimeRTC(byte* addr)
// Get number of seconds since 1/1/1970 by accessing DS1994 Real Time Clock registers
long GetTimeRTC(byte* addr)
      byte i;
      byte data[5];
      long utime;
      ds.reset();
      ds.select(addr);        // Button address
      ds.write(0xF0);         // Read memory
// Clock memory address starts at 0203h (dropping fraction of sec) Memory page 16
// 0203h = dec 515 or 001000000011
// Need to set address registers TA1 and TA2
// TA1 (8bit) first 5 bits represent byte offset within a page
// TA1 = 00000011 or 03h
// TA2 = 0010 or 02h
      ds.write(0x03);  //TA1
      ds.write(0x02);  //TA2
      for ( i = 1; i < 5; i++) { // we need 4 bytes of time data
      ds.reset();
// Convert 4 byte time data into 32 bit long int (sec from 1970:~1,215,011,006)
        utime = data[4];
        utime = utime<<8 | data[3];
        utime = utime<<8 | data[2];
        utime = utime<<8 | data[1];
        utime = data[4];
        for ( i = 3; i > 0; i--) { // we need 4 bytes of time data
            utime = utime<<8 | data[i];
     return utime;
and the result:
28.18
1251518460
28.12
1251518462
28.12
1251518463
28.12
1251518464
28.12
1251518465
28.12
1251518466
The datestamp is standard Unix, if you're using Linux or another *nix, its dead easy to do it in processing.
this will work in linux BASH - change 1250000000 to whatever your output is.
date -u --date="1970-01-01 1250000000 sec GMT"
example with output:
sv@Noo-one:~$ date -u --date="1970-01-01 1251518466 sec GMT"
Sat Aug 29 04:01:06 UTC 2009
Its completely alien to Windows, it could be done in arduino but it would take some doing. Its just a number of seconds which have elapsed since Midnight 1st Jan 1970. Gets messy with leap years and varying month lengths............
Take a look on DateTime library Arduino Playground - DateTime
