inspired by Arduino 1-Wire Address Finder -
I wrote a small sketch that scans all pins for 1 Wire devices.
The generator writes a small code snippet that can be used in other sketches.
// FILE: oneWireSearch.ino
// AUTHOR: Rob Tillaart
// VERSION: 0.1.04
// PURPOSE: scan for 1-Wire devices + code snippet generator
// DATE: 2015-june-30
// URL: http://forum.arduino.cc/index.php?topic=333923
// inspired by http://www.hacktronics.com/Tutorials/arduino-1-wire-address-finder.html
// Released to the public domain
// 0.1.00 initial version
// 0.1.01 first published version
// 0.1.02 small output changes
// 0.1.03 added more explicit range
// 0.1.04 added CRC check
// UNO 2..20
// MEGA and others have different range
const int startPin = 2;
const int endPin = 20;
#include <OneWire.h>
Serial.println("//\n// Start oneWireSearch.ino \n//");
for (uint8_t pin = startPin; pin < endPin; pin++)
findDevices(pin);
Serial.println("\n//\n// End oneWireSearch.ino \n//");
uint8_t findDevices(int pin)
OneWire ow(pin);
uint8_t address[8];
uint8_t count = 0;
if (ow.search(address))
Serial.print("\nuint8_t pin");
Serial.print(pin, DEC);
Serial.println("[][8] = {");
count++;
Serial.println(" {");
for (uint8_t i = 0; i < 8; i++)
Serial.print("0x");
if (address[i] < 0x10) Serial.print("0");
Serial.print(address[i], HEX);
if (i < 7) Serial.print(", ");
Serial.print(" },");
// CHECK CRC
if (ow.crc8(address, 7) == address[7])
Serial.println("\t\t// CRC OK");
Serial.println("\t\t// CRC FAILED");
} while (ow.search(address));
Serial.println("};");
Serial.print("// nr devices found: ");
Serial.println(count);
return count;
As always remarks, improvements etc are welcome
