1-Wire Slave
Hi Markus,
i tried the OneWireSlave-Library to work on an Arduino Pro Mini. If i compiled the example DS18B20_Slave_Interrupt_universal_analogread_fulllib.ino and i get the following errors:
In file included from DS18B20_Slave_Interrupt_universal_analogread_fulllib.ino:3: Eigene Dateien\Arduino\libraries\OneWireSlavemaster/OneWireSlave.h:140:4: error: #error "Not an Interrupt Pin" Eigene Dateien\Arduino\libraries\OneWireSlavemaster/OneWireSlave.h:141:4: error: #error "Use 0, 1, 2, 3, 4 or 5"
Is there a way to get this Library working with my Arduino Pro Mini?
regards
Michael
ok - think i got it.
In the DS18B20_Slave_Interrupt_universal_analogread_fulllib.ino i changed the dsslavepin to 1 - that worked.
The Sketch compiled.
Now i will try to test it out.
Is there anywhere a wiring scheme to connect to the 1wire-Bus?
Or will the following work:
Bus <-> Arduino
5V <-> 5V
GND <-> GND
Data <-> Pin1 (the pin assigned to dsslavepin)
Is this correct?
regards
Michael
soo...update:
i wired my nano like Markus as shown in Post #36. But my nano istn listet on my 1wire-Bus.
I set Pin2 as dsslavepin - but it seems that this doesnt work.
Markus: you got your Nano running as 1wire slave - what can i do to get mine working? :blush: Can you give me e litte hint?
You will need a 4.7K ohm resister between +5v and the data line for the arduino to act as a master.
I don't want the Arduino to act as a master. The Arduino should act as an 1wire slave.
For testings i have an Raspberry with an 1wire bus master to which i would connect the Arduino (as slave). The bus master works fine - tested with an normal DS18B20.
On this bus i connected the Arduino with the 1wire slave sketch - but the Arduino is not listed on the 1wire bus...
Bus <-> Arduino
5V <-> 5V
GND <-> GND
If you are not using the Raspberry +5v to power the Arduino it should not be connected to the Arduino +5v. You only need to connect GND and Data.
thanks for the hint.
so far i connected only the data pin (connected to digital2) and ground pin to the Arduino. At the moment the Arduino is powered via the usb connector.
however if i tested the simple code for simulating the DS1990A - the Arduino (simulated DS1990A) is not listed in the bus list. =( somehow i have no idea what i can do to get this setup work - but i know that it must work. Markus got this running on an Arduino nano if i am not wrong... :roll_eyes:
I have finally got ATTiny85’s working as 1-wire slaves but not using Markus’ library, I used a modified version of the one wire library from Alexander Gordeev . I finally succeeded once I discovered I could run the ATTiny85 at 16Mhz, that was the big breakthrough.
I now have ATTiny85s as slaves for a rain gauge and another for a humidity sensor. I am using the PinChange Interrupt Library so that the slaves only process one-wire commands once a One Wire Reset is detected. An LED flashes to provide visual feedback when the slave sends sensor data. Like the DS18B20 I use 0x44 as a request to calculate the sensor data and 0xBE to return the results.
I am running an Arduino as the weather station and One wire Master with Serial Communication to a computer. I had problems once I started adding multiple ATTiny85s but a 100nF decoupling ceramic capacitor across the +5v and GND lines has fixed them. My currently setup includes . . .
  • 1 x 4x20 LCD
  • 1 x MPL115A1 SPI Barometer
  • 1 x DS1904 One Wire Real Time Clock
  • 4 x DS18B20 One Wire Temperature Sensors
  • 1 x ATTiny85 One Wire Rain Gauge Sensor
  • 2 x ATTiny85 One Wire Humidity Sensors
I have attached the modified library along with the slave code for the rain Gauge and Humidity Sensors. The Weather Station Sketch is a work in progress that I am willing to make available should anyone be interested.
OWSlave.h (1.6 KB)
OWSlave.cpp (11.9 KB)
OWHumidity2.ino (5.96 KB)
OWRain1.ino (4.8 KB)
Punkt3: thanks for the hint.
Looks like I have some work to do!
Punkt3: soo...update:
Damn it really don't work on the Arduino Nano...
ATM. I will give the external ceramic resonator from the Nano the guiltiness, the ceramic resonator isn't as accurate as the crystal resonator who is used on the Leonardo or Uno. Following this http://jorisvr.nl/arduino_frequency.html
But this means the ATtiny85 with the internal RC would be more accurate than the ceramic resonator
So far so good, my Trinket response as 1-wire device with some drops on the line but works. For the next step an self calibration for the Nano and Trinket would be nice to solve the timing problems. I will try to include overdrive support
Did someone run 2 Nano's against another?
Hi guys, Can anyone give any guidance on using this library to make an Uno a 1-wire slave. I can get the "DS18B20_Slave_Interrupt_universal_analogread_fulllib.ino" example sketch to compile and upload fine by changing the dsslavepin (does this number refer to the actual pin or the interrupt no.?) I have another arduino with another DS18B20 and using the wire library example to get the addresses of the devices on the bus i only find the actual DS18B20. Has anyone had it working on an Uno and knows where i'm going wrong?
Hi Markus,
Does your library work with Arduino Uno?
I just released my library to make an Arduino board act as a 1-wire slave. You can download it here: https://github.com/neuoy/OneWireArduinoSlave
It's implemented using interrupts (everything is asynchronous, user code is notified by callbacks when bytes are received, etc.)
I've only tested it with an Arduino Uno and a DS9490R master (connected by USB to a laptop that acts as my home automation server). Works flawlessly so far in this setup, but let me know if you find bugs or can test it with other hardware setups (wether it works or not, I'm interested to know in both cases).
I was surprised how developing this kind of library is tricky, timings are sometimes as short as 3 microseconds or the master can miss bits, so debugging through Serial is not really an option, I acquired an USB oscilloscope for the occasion (very interesting project though).
Very nice! It's great to see a real C++ design and clean implementation that's easy-to-read. I've been helping someone over here, and had recently come to the conclusion that interrupts will have to be used for the exact reasons you state: 3us events.
As you said, this is definitely something that requires a 'scope or Logic Analyzer. The nice thing about the 'scope is that you can distinguish between active highs, input mode and multiple devices driving low. The user I am trying to help doesn't have either, and isn't very advanced in Arduino nor embedded techniques. It has been slow going.
While I've been reluctant to dive in and implement this, I have started on something. After looking at the timings and existing implementations, I was just starting to look at External Interrupts, Pin Change Interrupts and even the Input Capture. So thanks a million for this very "timely" post. ;)
Were you thinking about extending this to other types/numbers of 1-wire devices, or are you at the "good enough for me" stage?
BTW, have you seen Cosa? There are a few stylistic similarities, and I mean that as a compliment.
Cheers, /dev
Nice to see it can be useful to others :slight_smile:
Right now, it is indeed in a “good enough for me” stage. The goal was to provide a low level implementation only, because high level considerations (emulating specific devices such as temperature sensors or whatever) have a much larger scope, beyond what I can provide and support as a hobby, and also these are (somewhat) less difficult problems to solve. But it’s open source, so anyone can expand on it. Also, that doesn’t mean I won’t try to fix the bugs that are reported, if any :slight_smile:
I didn’t heard of Cosa, but it seems interesting, I’ll take a look, thanks.
About timing issues, I also tried with an active wait, and it was just a little bit slower, but I think it can work too. However, you really have to use 100% of the CPU to do just that, poll the pin state in a loop, and pull low as soon as you detect the edge (so you need to know if you’re going to pull low before starting the loop, to avoid too many instructions in between). So in my experience, interrupts are indeed more adequate to the task (a bit faster, and also less risk to miss an edge since the edge detection is hardware). Not sure how all these things will work (or not) on other boards though.
Hello Youen
Thank you very much for your lib.
My project is this one, and of course doesn't work: I have an home automation zwave device that can read DS18B20 1Wire sensors. I would like to use my Arduino UNO to send some value through this zwave module.
May you give me a simple example of code that sends a value when pressing a simple button?
I'm blocked trying to give your library a value to send (using your demo .ino ...).
Sorry for my completely noob question (i am really new to Arduino and totally off the computing universe) and thank you very much for your help!
The example does not seem to compile for ATTiny85:
In file included from ATTiny1WireSlave.ino:2:0:
E:\Docs\code\avr\arduino projects\libraries\OneWireArduinoSlave/LowLevel.h: In member function ‘void Pin::attachInterrupt(void (*)(), int)’:
E:\Docs\code\avr\arduino projects\libraries\OneWireArduinoSlave/LowLevel.h:113:3: error: ‘EIFR’ was not declared in this scope
EIFR |= (1 << INTF0); // clear any pending interrupt (we want to call the handler only for interrupts happending after it is attached)
I've gone through and replaced the offending items using the ATTiny85 and ATMega328 datasheets, namely:
EIFR --> GIFR TCCR1B --> TCCR0B WGM12 --> WGM02 TIMSK1 --> TIMSK
There may have been one more.
I don't know enough about the register functions to know where I have not gotten this right, but I definitely do not have a functioning example at the moment. The Tiny doesn't take down the bus, and have another device on there for a sanity check, so the bus and adapter are up. Just no ATTiny slave.
Colin
ilevans:
I could not get this to work. I had to all sorts of library moving, and eventually a type definition conflict with ‘boolean’. I renamed all instances in the libraries to ‘myboolean’ and resolved the conflict, but still no device on the bus.
You did not mention how you set the clock to internal 16MHz. The typical ATTiny board profiles for the Arduino IDE do not have a 16MHz internal option. Instead, I set up the Adafruit Trinket 16MHz definition and enabled as described here: 16MHz vs 8MHz Clock | Introducing Trinket | Adafruit Learning System
Still, no love.
Colin
Would this project be possible? :
  • a keypad identifies a user with a code
  • the accepted user code is send through 1Wire (as a DS18B20) to a 1Wire receiver that can only read a DS18B20
All of this on an Arduino UNO.
Thank you for your help
