I am using a Leonardo to create a replacement control board for an air conditioner.
The Leonardo is taking information from sensors, and controlling a bank of 8 relays.
Part of the system requires an alarm (an LED) to remind the user to clean the air filters every, say, 1 year. What hardware do I need to add to the Leonardo to acheive this? Do I need a second Leonardo? It really ought to be able to remember where it has got to, and be able to carry on from there, if there's a power cut.
You could use the Leonardo's EEPROM and keep track of how many hours (or tens of hours) have passed and assume that the occasional power outage doesn't really matter for filter reminding purposes. Just be aware that the EEPROM has a limited number of write cycles before it goes bad (~100,000). Alternatively, you could add a RTC and just store the time you last changed the filters in EEPROM. You'll need a switch for the user to reset the time when the filters are changed too.
I've been working on just such long delays as part of my initial Arduino timer study. All you need to do is count rollovers or overflows of a timer. Assuming a 16mhz clock, the max time of one 8 bit overflow, with a prescale of 1024 is 16.320 milliseconds. There are 31.558 x 10^6 seconds in a year, and that divided by 16.320x10^-3 = 193.400 x 106 overflows.
If you use Timer 1, the overflow is 65536 x 64 usecs or 4.19 SECONDS. So now we can divide the year of seconds by 4.19 seconds for an overflow count of 7.531 x 10^6. It turns out a LONG variable (32 bits) can hold a 4.29x10^9 counts - so you just set up a long variable, set timer 1 to CRC mode, set OCRA to TOP or 0xFFFF, set up an ISR. Each interrupt, increment your YEARCOUNT, and when it reaches 7.531 x 10^6 the year has ended!
My numbers (years and such) may be off a tad - I'm typing this in quickly. But the basic idea is to turn any long interval ( longer than 1 second) into a a number of seconds, the count the overflows. Naturally the final accuracy of this all depends on how much the Leonardo timer crystal drifts and other vague issues. But for a air conditioner filter-change alert, I suspect it will be fairly close and requires little technology to make it work.
=Alan R.
SpikeUK2564:
