10 bit PWM on Mega 2560
Hi everyone,
I'm building a resistor bank to test batteries at the moment. I can measure ampere with an accuracy of 0.5 A. Unfortunately the 8 bit PWM limits my ability to control amps to an accuracy of +- 2 A.
There are some posts about 10 bit PWM on the Arduino.
Here is what I found out:
I use PWM on Pin 6 and 7, that is Timer4, if I'm right.
Changing the frequency is easily done:
clear the last 3 bits of the 8 bit number with
TCCR4B &= ~7;
set prescaler
TCCR4B |= n;
with n = 1 for 31000 Hz, n = 2 for 4000 Hz, n = 3 for 490 Hz (default), n = 4 for 120 Hz, n = 5 for 30 Hz and n = 6 for 20 Hz
I got it from here.
That's what I got working.
According to this post it should be possible to change the PWM resolution to 10 bit, but I have absolutely no idea how to do that.
Do I have to change sbi(TCCR4A, WGM40) to sbi(TCCR4A, WGM41) in wiring.c?
Is there a way to change that in my program? I don't want to mess around with the arduino code and break something.
Maybe someone can point me in the right direction.
Thanks a lot
Time to read all about the 16-bit Counter/Timer registers in the datasheet. There are 15 PWM modes, most of them are 16-bit but there are two 10-bit PWM modes: Fast and Phase Correct. Pick one and learn what registers to set and how.
Is there another way, but the hard way? :wink:
I'm new to microcontroller, but I'm willing to learn...
16 bit resolution would be even better. I don't care about the exact waveform. Or should I when driving mosfets?
What I need is 10 or more bit resolution and the ability to set the frequency.
On page 148 in the datasheet I found the Modes of Operation. Is that the right place to look?
Mode 8 - 15 look like they are 16-bit.
So I need to set WGMn3, WGMn2, WGMn1 and WGMn0, right?
On the Secrets of Arduino PWM page the Mode is set by _BV(XXXXX), but when I write something like:
TCCR4A = _BV(WGM43) | _BV(WGM41) | _BV(WGM40);
the Arduino freezes. That's not the right way, is it?
Do you need a fairly exact frequency or just something in a general range? What frequency or frequencies do you want?
I think that Fast mode 16-bir PWM will have a maximum frequency of 244 Hz. Phase Correct mode will be half that.
I think that Fast mode 10-bit PWM will have a maximum frequency of 15,625 Hz.
