10 DOF IMU (MPU9255)
Hello,
I bought a 10DOF IMU module(Waveshare includes MPU9255) .I use the dome program on the following lines. I take the " connection failed" message but ı take all the pressure and temperature values correctly. What caused this situation ?
Regards
#include "Wire.h"
// I2Cdev and MPU9250 must be installed as libraries, or else the .cpp/.h files
// for both classes must be in the include path of your project
#include "I2Cdev.h"
#include "MPU9250.h"
#include "BMP180.h"
// class default I2C address is 0x68
// specific I2C addresses may be passed as a parameter here
// AD0 low = 0x68 (default for InvenSense evaluation board)
// AD0 high = 0x69
MPU9250 ag;
I2Cdev     I2C_M;
//SPI   spi;
uint8_t buffer_m[6];
int16_t ax, ay, az;
int16_t gx, gy, gz;
int16_t   mx, my, mz;
float heading;
float tiltheading;
float Axyz[3];
float Gxyz[3];
float Mxyz[3];
#define sample_num_mdate  5000
volatile float mx_sample[3];
volatile float my_sample[3];
volatile float mz_sample[3];
static float mx_centre = 0;
static float my_centre = 0;
static float mz_centre = 0;
volatile int mx_max = 0;
volatile int my_max = 0;
volatile int mz_max = 0;
volatile int mx_min = 0;
volatile int my_min = 0;
volatile int mz_min = 0;
float temperature;
float pressure;
float atm;
float altitude;
BMP180 Barometer;
    // join I2C bus (I2Cdev library doesn't do this automatically)
    Wire.begin();
    // initialize serial communication
    // (38400 chosen because it works as well at 8MHz as it does at 16MHz, but
    // it's really up to you depending on your project)
    // initialize device
    Serial.println("Initializing I2C devices...");
    ag.initialize();
    Barometer.init();
    // verify connection
    Serial.println("Testing device connections...");
    Serial.println(ag.testConnection() ? "MPU9250 connection successful" : "MPU9250 connection failed");
    Serial.println("     ");
      Mxyz_init_calibrated ();
    getAccel_Data();
    getGyro_Data();
    getCompassDate_calibrated(); // compass data has been calibrated here
    getHeading();               //before we use this function we should run 'getCompassDate_calibrated()' frist, so that we can get calibrated data ,then we can get correct angle .
    getTiltHeading();
    Serial.println("calibration parameter: ");
    Serial.print(mx_centre);
    Serial.print("         ");
    Serial.print(my_centre);
    Serial.print("         ");
    Serial.println(mz_centre);
    Serial.println("Acceleration(g) of X,Y,Z:");
    Serial.print(Axyz[0]);
    Serial.print(",");
    Serial.print(Axyz[1]);
    Serial.print(",");
    Serial.println(Axyz[2]);
    Serial.println("Gyro(degress/s) of X,Y,Z:");
    Serial.print(Gxyz[0]);
    Serial.print(",");
    Serial.print(Gxyz[1]);
    Serial.print(",");
    Serial.println(Gxyz[2]);
    Serial.println("Compass Value of X,Y,Z:");
    Serial.print(Mxyz[0]);
    Serial.print(",");
    Serial.print(Mxyz[1]);
    Serial.print(",");
    Serial.println(Mxyz[2]);
    Serial.println("The clockwise angle between the magnetic north and X-Axis:");
    Serial.print(heading);
    Serial.println("The clockwise angle between the magnetic north and the projection of the positive X-Axis in the horizontal plane:");
    Serial.println(tiltheading);
    temperature = Barometer.bmp180GetTemperature(Barometer.bmp180ReadUT()); //Get the temperature, bmp180ReadUT MUST be called first
    pressure = Barometer.bmp180GetPressure(Barometer.bmp180ReadUP());//Get the temperature
    altitude = Barometer.calcAltitude(pressure); //Uncompensated caculation - in Meters
    atm = pressure / 101325;
    Serial.print("Temperature: ");
    Serial.print(temperature, 2); //display 2 decimal places
    Serial.println("deg C");
    Serial.print("Pressure: ");
    Serial.print(pressure, 0); //whole number only.
    Serial.println(" Pa");
    Serial.print("Ralated Atmosphere: ");
    Serial.println(atm, 4); //display 4 decimal places
    Serial.print("Altitude: ");
    Serial.print(altitude, 2); //display 2 decimal places
    Serial.println(" m");
void getHeading(void)
    heading = 180 * atan2(Mxyz[1], Mxyz[0]) / PI;
    if (heading < 0) heading += 360;
void getTiltHeading(void)
    float pitch = asin(-Axyz[0]);
    float roll = asin(Axyz[1] / cos(pitch));
    float xh = Mxyz[0] * cos(pitch) + Mxyz[2] * sin(pitch);
    float yh = Mxyz[0] * sin(roll) * sin(pitch) + Mxyz[1] * cos(roll) - Mxyz[2] * sin(roll) * cos(pitch);
    float zh = -Mxyz[0] * cos(roll) * sin(pitch) + Mxyz[1] * sin(roll) + Mxyz[2] * cos(roll) * cos(pitch);
    tiltheading = 180 * atan2(yh, xh) / PI;
    if (yh < 0)    tiltheading += 360;
void Mxyz_init_calibrated ()
    Serial.println(F("Before using 9DOF,we need to calibrate the compass frist,It will takes about 2 minutes."));
    Serial.print("  ");
    Serial.println(F("During  calibratting ,you should rotate and turn the 9DOF all the time within 2 minutes."));
    Serial.print("  ");
    Serial.println(F("If you are ready ,please sent a command data 'ready' to start sample and calibrate."));
    while (!Serial.find("ready"));
    Serial.println("ready");
    Serial.println("Sample starting......");
    Serial.println("waiting ......");
    get_calibration_Data ();
    Serial.println("compass calibration parameter ");
    Serial.print("     ");
    Serial.print("     ");
void get_calibration_Data ()
    for (int i = 0; i < sample_num_mdate; i++)
        get_one_sample_date_mxyz();
        Serial.print(mx_sample[2]);
        Serial.print(" ");
        Serial.print(my_sample[2]);                            //you can see the sample data here .
        Serial.print(" ");
        Serial.println(mz_sample[2]);
        if (mx_sample[2] >= mx_sample[1])mx_sample[1] = mx_sample[2];
        if (my_sample[2] >= my_sample[1])my_sample[1] = my_sample[2]; //find max value
        if (mz_sample[2] >= mz_sample[1])mz_sample[1] = mz_sample[2];
        if (mx_sample[2] <= mx_sample[0])mx_sample[0] = mx_sample[2];
        if (my_sample[2] <= my_sample[0])my_sample[0] = my_sample[2]; //find min value
        if (mz_sample[2] <= mz_sample[0])mz_sample[0] = mz_sample[2];
    mx_max = mx_sample[1];
    my_max = my_sample[1];
    mz_max = mz_sample[1];
    mx_min = mx_sample[0];
    my_min = my_sample[0];
    mz_min = mz_sample[0];
    mx_centre = (mx_max + mx_min) / 2;
    my_centre = (my_max + my_min) / 2;
    mz_centre = (mz_max + mz_min) / 2;
void get_one_sample_date_mxyz()
    getCompass_Data();
    mx_sample[2] = Mxyz[0];
    my_sample[2] = Mxyz[1];
    mz_sample[2] = Mxyz[2];
void getAccel_Data(void)
    ag.getMotion9(&ax, &ay, &az, &gx, &gy, &gz, &mx, &my, &mz);
    Axyz[0] = (double) ax / 16384;
    Axyz[1] = (double) ay / 16384;
    Axyz[2] = (double) az / 16384;
void getGyro_Data(void)
    Gxyz[0] = (double) gx * 250 / 32768;
    Gxyz[1] = (double) gy * 250 / 32768;
    Gxyz[2] = (double) gz * 250 / 32768;
void getCompass_Data(void)
    I2C_M.writeByte(MPU9250_MAG_ADDRESS, 0x0A, 0x01); //enable the magnetometer
    delay(10);
    I2C_M.readBytes(MPU9250_MAG_ADDRESS, MPU9250_MAG_XOUT_L, 6, buffer_m);
    mx = ((int16_t)(buffer_m[1]) << 8) | buffer_m[0] ;
    my = ((int16_t)(buffer_m[3]) << 8) | buffer_m[2] ;
    mz = ((int16_t)(buffer_m[5]) << 8) | buffer_m[4] ;
    Mxyz[0] = (double) mx * 1200 / 4096;
    Mxyz[1] = (double) my * 1200 / 4096;
    Mxyz[2] = (double) mz * 1200 / 4096;
void getCompassDate_calibrated ()
    getCompass_Data();
    Mxyz[0] = Mxyz[0] - mx_centre;
    Mxyz[1] = Mxyz[1] - my_centre;
    Mxyz[2] = Mxyz[2] - mz_centre;
Can anyone help me ?
The mpu9255 is a mpu6050 with an internal Compass chip attached to the secondary i2c buss just as if you were to attach it externally on the MPU6050 so all MPU6050 code should work except I had to wright alternate calibration code to get correct offsets.
Try this out for calibration values
Z
MPU-9255Cal.ino (44.7 KB)
Hello God Member,
I have Waveshare 10 DOF IMU module. As far as I understood, I should " MPU6050.h" file for accelerometer and gyroscope. Which program should I be loaded for magnetometer ?
For an example program, I found the following program from github files.
#include "Wire.h"
#include "I2Cdev.h"
#include "BMP180.h"
// AD0 high = 0x69
MPU9250 accelgyro;
const int MPU_addr=0x68;
I2Cdev   I2C_M;
int16_t ax, ay, az;
int16_t gx, gy, gz;
int16_t   mx, my, mz;
float heading;
float tiltheading;
float Axyz[3];
float Gxyz[3];
float Mxyz[3];
float temperature;
float pressure;
float atm;
float altitude;
BMP180 Barometer;
    Wire.begin();
    Serial.begin(38400);
    accelgyro.initialize();
    Barometer.init();
    Serial.println(accelgyro.testConnection() ? "MPU9250 connection successful" : "MPU9250 connection failed");
    //  Mxyz_init_calibrated ();
    getAccel_Data();
    getGyro_Data();
    getTiltHeading();
    Serial.print("         ");
    Serial.print("         ");
    Serial.print(",");
    Serial.print(",");
    Serial.print(",");
    Serial.print(",");
    Serial.print(",");
    Serial.print(",");
    Serial.print("  ");
    Serial.print("  ");
    Serial.print("     ");
    Serial.print("     ");
        Serial.print(" ");
        Serial.print(" ");
    getCompass_Data();
    accelgyro.getMotion9(&ax, &ay, &az, &gx, &gy, &gz, &mx, &my, &mz);
    delay(10);
    getCompass_Data();
Can I use this program for demostration ?
bmkaya:
Hello God Member,
The 9250 and the 9255 have different internal manometers attached to the internal MPU6050 in them but if I remember correctly I believe the code should work on both. I haven't tried it out lately but if there is a difference it will be in the addressing of where the data is and or the i2c address of the manometer.
I have a MPU9255 in my inventory I will try your code out to see if i find any issues.
Z
Hello God Member,
In some documents,
it is said that Waveshape 10 DOF IMU includes HMC5883L moaometer but others the manometer module is an AK8963. I tried both of them with their Arduino raw code , system gave connection failure. I tried with an 0x0C device address , system worked without problems. Which manometer is included ?
Mine has AK8963 and the address is 0x48.
But the magnetometer offset changes a lot every time we test it.
Trying to replace them with BNO055.
Hope this help
