I have this working so when I upload the .ino to my UNO it sends a SMS to my cell phone. I want it to send a SMS each time a button it pressed like on Digital pin 2. I'm in my 60's and cant figure out how to do it and I need it soon. Thanks
Send SMS from Arduino over the Internet using ENC28J60 and Thingspeak
Change one line to use with ethernet shield
Add sensor readings in the loop and a time interval
Using Arduino UIP library from https://github.com/ntruchsess/arduino_uip
Code based on Sparkfun's data logging service data.sparkfun.com
URL encode function from http://hardwarefun.com/tutorials/url-encoding-in-arduino
#include <SPI.h>
//change the following line to #include <Ethernet.h> to use the eithent shield
// Enter a MAC address for your controller below.
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
//thingspeak server
char server[] = "api.thingspeak.com";
//if DHCP fails, use a static IP
IPAddress ip(192,168,0,177);
// Initialize the Ethernet client library
EthernetClient client;
//API key for the Thingspeak ThingHTTP already configured
const String apiKey = "YW9TOU470F0XXXXX";
//the number the message should be sent to
const String sendNumber = "151524XXXXX";
//set up Ethernet:
setupEthernet();
//send the sms
Serial.println("Sending SMS");
//this function will send the sms
//the first argument is the number to send to, formatted like this +12345678901
//the second argument is the body of the text message, which must be within URLEncode()
sendSMS(sendNumber, URLEncode("Hello World!"));
void sendSMS(String number,String message)
// Make a TCP connection to remote host
if (client.connect(server, 80))
//should look like this...
//api.thingspeak.com/apps/thinghttp/send_request?api_key={api key}&number={send to number}&message={text body}
client.print("GET /apps/thinghttp/send_request?api_key=");
client.print(apiKey);
client.print("&number=");
client.print(number);
client.print("&message=");
client.print(message);
client.println(" HTTP/1.1");
client.print("Host: ");
client.println(server);
client.println("Connection: close");
client.println();
Serial.println(F("Connection failed"));
// Check for a response from the server, and route it
// out the serial port.
while (client.connected())
if ( client.available() )
char c = client.read();
Serial.print(c);
client.stop();
void setupEthernet()
Serial.println("Setting up Ethernet...");
// start the Ethernet connection:
if (Ethernet.begin(mac) == 0) {
Serial.println(F("Failed to configure Ethernet using DHCP"));
// no point in carrying on, so do nothing forevermore:
// try to congifure using IP address instead of DHCP:
Ethernet.begin(mac, ip);
Serial.print("My IP address: ");
Serial.println(Ethernet.localIP());
// give the Ethernet shield a second to initialize:
String URLEncode(const char* msg)
const char *hex = "0123456789abcdef";
String encodedMsg = "";
while (*msg!='\0'){
if( ('a' <= *msg && *msg <= 'z')
|| ('A' <= *msg && *msg <= 'Z')
|| ('0' <= *msg && *msg <= '9') ) {
encodedMsg += *msg;
else {
encodedMsg += '%';
encodedMsg += hex[*msg >> 4];
encodedMsg += hex[*msg & 15];
msg++;
return encodedMsg;
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
ThingSpeakTwilio.ino (3.21 KB)
