To really see the benefit of using arrays, I would have a Servo array as well.
That way you can do:
const byte NUMBER_OF_SERVOS = 10;
//later in code
//set all servos position equal to the potvals
for (byte i=0; i<NUMBER_OF_SERVOS; i++){
servo[i].write(potvals[i]);
Well, I should of probably defined what I am trying to do before anything lol
I'm trying to control 10 servos with 10 5K potentiometers each with assigned to each other and able to move independently (or physically appearing to do so).
The megaservo example looks similar to what Alpha posted, but that just moves multiple servos with one potentiometer, and assume that the code is similar to physically wiring the servos in parallel.
And anyone know how to patch the IDE 17 on a mac for the Arduino Mega bug?
EDIT: Another thing; this really confuses me (maybe I'm just thinking too much :p). All the examples I've seen with a analog input and digital output, just has the pins/objects assigned just by using the pin numbers. Where I'm confused is to how it knows if you are referring to an analog pin or a digital pin?
like in this example int the learning section:
// Controlling a servo position using a potentiometer (variable resistor)
// by Michal Rinott <http://people.interaction-ivrea.it/m.rinott>
#include <Servo.h>
Servo myservo; // create servo object to control a servo
int potpin = 0; // analog pin used to connect the potentiometer
int val; // variable to read the value from the analog pin
myservo.attach(9); // attaches the servo on pin 9 to the servo object
val = analogRead(potpin); // reads the value of the potentiometer (value between 0 and 1023)
val = map(val, 0, 1023, 0, 179); // scale it to use it with the servo (value between 0 and 180)
myservo.write(val); // sets the servo position according to the scaled value
delay(15); // waits for the servo to get there
I don't know if you caught this, but your "potpins" and "potvals" variables aren't the same size. If you're trying to use 10 inputs, potpins will be 0 to 9 (which is ten numbers), and your potvals should be an array with 10 values (potvals[10]). Then, when you read, you can do for(i=0; i<10; i++). This reads values 0 through 9 (10 values). You have to remember you're starting your counting from 0 now, not from 1 like humans are used to.
To patch the library, you'll have to edit the file wiring_analog.c. Instructions on what to do are here: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1250970792 I don't know where the arduino lives on a mac, so you can probably just do a search for the file.
As for which pins you read, that's built into the Arduino IDE. analogRead() knows which pins are the analog pins, and digitalRead() knows which pins are digital. The Arduino guys did all of that coordination for you, so digitalRead(10) reads from the digital pin with the 10 silkscreened next to it.
jpgr87: Yes I'm pretty sure we know. We were just focusing on the errors that I was posting.
That link does nothing for me because I'm on a mac and the wiring_analog.c file isn't found just by a simple search. Its most likely in a compressed file somewhere, which I am unable to find.
EDIT: well, I found it and it appears to be already patched
The MegaServo example reads one pot and uses that value to control all the servos. AlhpaBeta's post shows how to change it so that a different pot can be used for of each servo.
Here is the full sketch with that change:
#include <Servo.h>
#define NBR_SERVOS 10 // the number of servos
#define FIRST_SERVO_PIN 2 // this first of consecutive digital pins used for servos
Servo Servos[NBR_SERVOS] ; // an array of servo objects
// attach all 10 servos to digital pins starting from 2
for( int i =0; i < NBR_SERVOS; i++)
Servos[i].attach( FIRST_SERVO_PIN +i, 800, 2200);
int pos = 0; // variable to store the servo position
for( int i =0; i <NBR_SERVOS; i++)
pos = analogRead(i); // read a value from pins 0 to 9
Servos[i].write( map(pos, 0,1023,0,180)); // and write the value to the servo
delay(15);
I just had another question come to mind. I've read somewhere that you can use a servo as a sensor. If thats the case, then with a SDcard shield would I be able to record live readings from the servos and play them back?
That depends on what you want to sense. As AWOL says, if you want to get the physical position you would need to modify the servo. But if you want to play back a sequence of servo movements its much easier to either store the values (and time) that are written to the servos, or to regularly read and store the servo position using servo.read().
Hi, my name is Guzz and i'm new on the arduino world. I'm having some trouble to write a code to control 4 servos with a arduino, and i dont know what can be wrong with my code, i'm not a programmer (yet). I wrote this code based on de sweep code from the arduino examples. The code compiles fine, but when i try to upload to the board it crashes. Im using the arduino duemilanove with atmega 328. The code is like this...
#include <Servo.h>
Servo myservo0; // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos0 = 0; // variable to store the servo position
Servo myservo1; // create servo object to control a servo
int pos1 = 0; // variable to store the servo position
Servo myservo2; // create servo object to control a servo
int pos2 = 0; // variable to store the servo position
Servo myservo3; // create servo object to control a servo
int pos3 = 0; // variable to store the servo position
myservo0.attach(9); // attaches the servo on pin 9 to the servo object
myservo1.attach(8); // attaches the servo on pin 8 to the servo object
myservo2.attach(7); // attaches the servo on pin 7 to the servo object
myservo3.attach(5); // attaches the servo on pin 5 to the servo object
for(pos0 = 0; pos0 < 180; pos0 += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo0.write(pos0); // tell servo to go to position in variable 'pos'
delay(5); // waits 15ms for the servo to reach the position
for(pos0 = 180; pos0>=1; pos0-=1) // goes from 180 degrees to 0 degrees
for(pos1 = 0; pos1 < 180; pos1 += 1) // goes from 0 degrees to 180 degrees
myservo1.write(pos1); // tell servo to go to position in variable 'pos'
for(pos1 = 180; pos1>=1; pos1-=1) // goes from 180 degrees to 0 degrees
for(pos2 = 0; pos2 < 180; pos2 += 1) // goes from 0 degrees to 180 degrees
myservo2.write(pos2); // tell servo to go to position in variable 'pos'
for(pos2 = 180; pos2>=1; pos2-=1) // goes from 180 degrees to 0 degrees
myservo2.write(pos0); // tell servo to go to position in variable 'pos'
for(pos3 = 0; pos3 < 180; pos3 += 1) // goes from 0 degrees to 180 degrees
myservo3.write(pos3); // tell servo to go to position in variable 'pos'
for(pos3 = 180; pos3>=1; pos3-=1) // goes from 180 degrees to 0 degrees
If someone could please take a look and tell me what could be wrong i'd be most greatfull.
PS: I wasnt sure if i should create a new post, but since we are discussing servos and arduino here i was hoping no one would mind.
If you're powering the four servos from the Arduino, it is likely that the crash is due to the excessive current being drawn, pulling down the voltage to the processor and causing it to brown-out or reset.
Power the servos from a separate supply (4 AA batteries should do it), and remember to common the grounds.
I can't see anything obvious in your code that would cause a crash.
Please use the Code (#) button when posting code, and it is best not to hijack other threads.
No worries.
We programmers are lazy types, so I re-wrote your sketch to make it a bit shorter: [uncompiled, untested]
#include <Servo.h>
Servo myservo [4]; // create servo object to control four servos
int pos [4] = 0; // variable to store the servo position
myservo[0].attach(9); // attaches the servo on pin 9 to a servo object
myservo[1].attach(8); // attaches the servo on pin 8 to a servo object
myservo[2].attach(7); // attaches the servo on pin 7 to a servo object
myservo[3].attach(5); // attaches the servo on pin 5 to a servo object
for (int i = 0; i < 4; ++i) {
for(pos[i] = 0; pos[i] < 180; pos[i] += 1)
myservo[i].write(pos[i]);
delay(5); // waits 5ms for the servo to reach the position
for(pos[i] = 180; pos[i]>=1; pos[i]-=1) // goes from 180 degrees to 0 degrees
myservo[i].write(pos[i]); // tell servo to go to position in variable 'pos'
