Hello, I'm working on just displaying simple temperature sensor using a 10k Thermistor with a 10k Resistor on 5v. Everything is working however in displaying the temperature looks way to high its showing 76c when I know for a fact it is not that hot in my room it shows 21.6c. I'm not sure what is wrong with the coding. I also added a 128x64 oled 1.3". Attching the coding below. I'm not good with temperature stuff or what I'm doing wrong in coding. It is what I found online and modded together.
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <math.h> //loads the more advanced math functions
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
#if (SSD1306_LCDHEIGHT != 64)
#error("Height incorrect, please fix Adafruit_SSD1306.h!");
#endif
// by default, we'll generate the high voltage from the 3.3v line internally! (neat!)
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // initialize with the I2C addr 0x3D (for the 128x64)
// init done
// Show image buffer on the display hardware.
// Since the buffer is intialized with an Adafruit splashscreen
// internally, this will display the splashscreen.
display.display();
delay(2000);
// Clear the buffer.
display.clearDisplay();
// draw a single pixel
display.drawPixel(10, 10, WHITE);
// Show the display buffer on the hardware.
// NOTE: You _must_ call display after making any drawing commands
// to make them visible on the display hardware!
display.display();
delay(2000);
display.setTextSize(2);
display.setTextColor(WHITE);
display.print("Designed by "); display.println( "me");
display.display();
delay(2000);
double Thermister(int RawADC) { //Function to perform the fancy math of the Steinhart-Hart equation
double Temp;
Temp = log(((10240000/RawADC) - 10000));
Temp = 1 / (0.001129148 + (0.000234125 + (0.0000000876741 * Temp * Temp ))* Temp );
Temp = Temp - 273.15; // Convert Kelvin to Celsius
Temp = (Temp * 9.0)/ 5.0 + 32.0; // Celsius to Fahrenheit - comment out this line if you need Celsius
return Temp;
int val; //Create an integer variable
double temp; //Variable to hold a temperature value
val=analogRead(0); //Read the analog port 0 and store the value in val
temp=Thermister(val); //Runs the fancy math on the raw analog value
// Serial.println(temp); //Print the value to the serial port
display.setCursor(10, 0);
display.print(temp); display.println("c");
display.display();
delay(1000); //Wait one second before we do it again
Can someone help me please to figure this problem out?
Edit:
This is the code for the thermistor and This is the code for the LCD display.
Joseph
