100 psi pressure sensor
Hello,
I'm new here and I have found same kind of problems but none of them is helping me. :confused:
Problem is to get 0.5 - 4.5 v pressure sensor (three wires, GND, 5v, and signal) show me PSI. I have four of them in my air ride system. Arduino is connected to tablet with HC-06 bt.
Sensor is linear 0v = 0psi, 4.5v = 100psi.
http://www.ebay.co.uk/itm/100psi-NPT1-8-Pressure-Transducer-Sender-for-Oil-Fuel-Diesel-Gas-Water-Air-New-/301873211189?hash=item46490ba735:g:A4kAAOSw3KFWb9x-
Sensos are connected to 5v supply, GND and analog in A1-A4.
Analog is giving me 0-1023, sensor 0.5-4.5v but how to get them together to PSI.
Can anyone make this working? ;D
EDIT: Something went right and this is working now!
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Lookup the map function.
Tom.. :slight_smile:
Mara933:
It would be better if you posted a new message saying that, rather than go back and embed it in your first message.
What was the solution?
Tom…
