100a current sensor
Hello
Wonder of someone could help me please I want to make a 100 amp current sensor using the alegro acs 758 100 amp current sensor, I can't program I wonder if there is a sketch somewhere with an lcd?
Thank you
As its output is analog, you just have to connect it to a arduino analog pin, get the reading, and display it.
Reading from your other posts it seems you have some disabilities.
Have you done any coding before?
If you google acs758 arduino
You will find YouTube and other sources that have used that sensor, it is quite popular to use with microcontrollers.
What model controller are you aiming to use and what sort of display or data transfer?
Thanks.. Tom.. :slight_smile:
:slight_smile: i suffer cronic pain, difficult to concentrate, im clued up on uno and electronics just cant code
Ive already built my project jusr need to find some code.
Want to use a 2 line lcd to display output result v and amps im using a nano.
Im sure ive seen someone usinf that sensor just wondering if anybody has seen a sketch somewhere ?
Nobody can help you if you don't tell us what you want to measure.
AC or DC, and what sort of load (motor, PWM?).
And which LCD you're using (parallel or I2C).
Please try, if you can, to post code you already have.
Leo..
To give you some sample code, we need to know how you have connected the current sensor and the LCD display.
Have you tried the example code for the LCD to make sure it works before adding any extra code?
Tom... :slight_smile:
