Hi everyone.
I have been working through some code utilizing examples and online support to try and develop some code which will record data from the SparkFun Micro 6DoF IMU - ISM330DHCX sensor at 100Hz onto an SD card via the SparkFun ESP32 RedBoard.
I also have a SparkFun RV1805 RTC in the circuit to help sync everything at 100Hz.
So far I am not able to get a solid and reliable 100Hz logging. This may be a hardware limitation of the sensor, I'm not 100% sure.
I have included a copy of the code I've been working on. Any help would be greatly appreciated.
Thanks everyone.
#include <Wire.h>
#include <SD.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_ISM330DHCX.h>
#include <SparkFun_RV1805.h>
#define CS_PIN 5
RV1805 rtc; // Create an RV-1805 RTC object
Adafruit_ISM330DHCX imu; // Create an ISM330DHCX object
const unsigned long SAMPLE_INTERVAL = 10; // Sampling interval in milliseconds (100Hz)
const unsigned long RECORDING_DURATION = 60000; // Recording duration in milliseconds (60 seconds)
const char* FILENAME = "/sensor_data.csv"; // File name to save data
File dataFile;
unsigned long recordingStartTime = 0;
unsigned long lastSampleTime = 0;
unsigned long startTimeMillis = 0;
Wire.begin();
if (!SD.begin(CS_PIN)) {
Serial.println("Error initializing SD card.");
while (true);
if (!imu.begin_I2C(0x6B)) {
Serial.println("Couldn't find ISM330DHCX sensor.");
while (true);
if (!rtc.begin()) {
Serial.println("Couldn't find RV1805 RTC.");
while (true);
recordingStartTime = millis();
lastSampleTime = recordingStartTime;
startTimeMillis = rtc.getEpoch(); // Get the RTC start time in seconds
dataFile = SD.open(FILENAME, FILE_WRITE);
if (dataFile) {
// Print headers to the data file
dataFile.println("Timestamp (ms),Acceleration X (mg),Acceleration Y (mg),Acceleration Z (mg),Gyro X (dps),Gyro Y (dps),Gyro Z (dps)");
dataFile.close();
Serial.println("Error opening data file.");
unsigned long currentTime = millis();
if (currentTime - recordingStartTime >= RECORDING_DURATION) {
dataFile.close();
Serial.println("Recording complete.");
while (true);
if (currentTime - lastSampleTime >= SAMPLE_INTERVAL) {
recordSensorData(currentTime);
lastSampleTime = currentTime;
void recordSensorData(unsigned long currentTime) {
dataFile = SD.open(FILENAME, FILE_APPEND);
if (dataFile) {
sensors_event_t accel;
sensors_event_t gyro;
sensors_event_t temp;
imu.getEvent(&accel, &gyro, &temp);
// Convert acceleration and gyro values to millig's and degrees per second
float accelX_mg = accel.acceleration.x * 1000.0;
float accelY_mg = accel.acceleration.y * 1000.0;
float accelZ_mg = accel.acceleration.z * 1000.0;
float gyroX_dps = gyro.gyro.x;
float gyroY_dps = gyro.gyro.y;
float gyroZ_dps = gyro.gyro.z;
float temp_deg = temp.temperature;
// Get the current time from the RTC and calculate the timestamp in milliseconds
unsigned long currentTimeRTC = rtc.getEpoch();
unsigned long timestamp_ms = (currentTimeRTC - startTimeMillis) * 1000 + (currentTime % 1000);
// Print data to the data file with the timestamp
dataFile.print(timestamp_ms);
dataFile.print(",");
dataFile.print(accelX_mg);
dataFile.print(accelY_mg);
dataFile.print(accelZ_mg);
dataFile.print(gyroX_dps);
dataFile.print(gyroY_dps);
dataFile.print(gyroZ_dps);
dataFile.println(temp_deg);
dataFile.close();
