The passage here describes the current problem I am facing with data Acquisition from Board NODEMCU1.0 (ESP12-E).
I have written a program which analogs read in 2 ms( more precisely "within 2 ms"). This acts as web server if you go to the IP address of web server, a hex file is downloaded containing all the data. The problem is ,even for 1000 data point which should take less than 2 seconds it, it takes 15-30 min to download the file, which is weird.
I know that the data point is collected within 2 ms because the code checks for it. There is no way data acquisition is going on for that long.
Since I have little to no knowledge on TCP connection , can you guess What could be the problem.
Read this forum to know more( [SOLVED]Faster Uploading from ESP8266 - Programming Questions - Arduino Forum). The imp stuff start from #10 message, all above are rubbish.
TUNIOT__8905.ino (1.18 KB)
