Hello,
I'm new in Arduino world. I'm trying to implement CANbus sniffer.
There are a lot of projects and libraries available - hard to choose.
What is you recommendation ?
ca
For a start, I've chosen 107-Arduino-MCP2515 library installed from inside IDE.
I've taken CANBus sniffer example project and I'm trying to compile it for Mega.
I get following error (highlight and full log output below).
Any advice, help ?
Thanks in advance,
regards bulek.
fatal error: functional: No such file or directory
#include <functional>
compilation terminated.
Full output :
Arduino: 1.8.12 (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Robi\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -ide-version=10812 -build-path C:\Users\Robi\AppData\Local\Temp\arduino_build_338916 -warnings=none -build-cache C:\Users\Robi\AppData\Local\Temp\arduino_cache_246 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Robi\Documents\Arduino\MCP2515-CAN-Sniffer\MCP2515-CAN-Sniffer.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Robi\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -ide-version=10812 -build-path C:\Users\Robi\AppData\Local\Temp\arduino_build_338916 -warnings=none -build-cache C:\Users\Robi\AppData\Local\Temp\arduino_cache_246 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Robi\Documents\Arduino\MCP2515-CAN-Sniffer\MCP2515-CAN-Sniffer.ino
Using board 'mega' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\mega" "C:\\Users\\Robi\\AppData\\Local\\Temp\\arduino_build_338916\\sketch\\MCP2515-CAN-Sniffer.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\mega" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "C:\\Users\\Robi\\AppData\\Local\\Temp\\arduino_build_338916\\sketch\\MCP2515-CAN-Sniffer.ino.cpp" -o nul
Alternatives for ArduinoMCP2515.h: [107-Arduino-MCP2515@1.2.2]
ResolveLibrary(ArduinoMCP2515.h)
-> candidates: [107-Arduino-MCP2515@1.2.2]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\mega" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\Robi\\Documents\\Arduino\\libraries\\107-Arduino-MCP2515\\src" "C:\\Users\\Robi\\AppData\\Local\\Temp\\arduino_build_338916\\sketch\\MCP2515-CAN-Sniffer.ino.cpp" -o nul
Alternatives for functional: []
ResolveLibrary(functional)
-> candidates: []
In file included from C:\Users\Robi\Documents\Arduino\libraries\107-Arduino-MCP2515\src/ArduinoMCP2515.h:18:0,
from C:\Users\Robi\Documents\Arduino\MCP2515-CAN-Sniffer\MCP2515-CAN-Sniffer.ino:12:
C:\Users\Robi\Documents\Arduino\libraries\107-Arduino-MCP2515\src/MCP2515/MCP2515_Io.h:19:10: fatal error: functional: No such file or directory
Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
Using library 107-Arduino-MCP2515 at version 1.2.2 in folder: C:\Users\Robi\Documents\Arduino\libraries\107-Arduino-MCP2515
exit status 1
Error compiling for board Arduino Mega or Mega 2560.
