12/24 hour clock conversion.
I'm trying to display a 12 hour clock on a liquid crystal display. no matter how I try I keep getting this error...
"cannot resolve overloaded function 'hour' based on conversion to type 'bool'"
#include <Wire.h>
#include <DS3232RTC.h>
#define DS3232RTC.h
#define HR1224 6
#include <Time.h>
#include <Arduino.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);//RS, E, D4, D5, D6, D7
int RelayL = 8;//Relay Large Tank
int RelayS = 9;//Relay Small Tank
const int HTempSensorPin0 = 4;// A4 Hot Side Large Tank
const int CTempSensorPin2 = 6;// A6 Cold Side Large Tank
const int HTempSensorPin1 = 5;// A5 Hot Side Small Tank
const int CTempSensorPin3 = 7;// A7 Cold Side Small Tank
float readTemp(int aPin)
  int value = analogRead(aPin);
  float millivolts = (value / 1024.0) * 5000;
  float celcius = millivolts / 10;
  return (celcius * 9) / 5 + 32;
  setSyncProvider(RTC.get);   //  tells the Time library where it can get the time from
  pinMode(RelayL,OUTPUT);
  pinMode(RelayS,OUTPUT);
  lcd.begin(20, 4);
  lcd.setCursor(4, 1);
  lcd.print("Loading...");
  lcd.setCursor(4, 2);
  lcd.print("Please Wait");
    lcd.clear();
  lcd.begin(20, 4);
  lcd.setCursor(7, 1);
  lcd.print("Done");
    delay(700);
    lcd.clear();
  char buffer[10];
  time_t t = now();
  sprintf(buffer, "%02d:%02d:%02d", hour(t), minute(t), second(t));
  Serial.println(buffer);
  Serial.println(" ");
  Serial.println("Hot Side Large Tank");
  Serial.println(readTemp(HTempSensorPin0));
  Serial.println("Cold Side Large Tank");
  Serial.println(readTemp(CTempSensorPin2));
  Serial.println("Hot Side Small Tank");
  Serial.println(readTemp(HTempSensorPin1));
  Serial.println("Cold Side Small Tank");
  Serial.println(readTemp(CTempSensorPin3));
    if (hour()<12)
      lcd.setCursor(0, 3);
      lcd.print(hour());
      lcd.setCursor(2,3);
      lcd.print(":");
      lcd.print(minute());
      lcd.setCursor(6,3);
      lcd.print("AM");
    if (hour()>=12)
      lcd.print(hour());
      lcd.setCursor(2,3);
      lcd.print(":");
      lcd.setCursor(6,3);
      lcd.print("PM");
    if (minute()<10)
      lcd.print(hour());
      lcd.setCursor(2,3);
      lcd.print(":");
      lcd.setCursor(3,3);
      lcd.print("0");
    if (minute()>=10)
      lcd.print(hour());
      lcd.setCursor(2,3);
      lcd.print(":");
      lcd.setCursor(3,3);
    lcd.setCursor(2, 1);
    lcd.print(readTemp(HTempSensorPin0));//LG TANK HOT
    lcd.print("F");//Fahrenheit
    lcd.setCursor(0, 0);
    lcd.print("LG Tank");//Tank
    lcd.setCursor(0, 1);
    lcd.print("H");//Hot
    lcd.setCursor(2, 2);
    lcd.print(readTemp(CTempSensorPin2));//LG TANK COLD
    lcd.setCursor(0,2);
    lcd.print("C");//Cold
    lcd.setCursor(13, 1);
    lcd.print(readTemp(HTempSensorPin1));//SM TANK HOT
    lcd.setCursor(11,0);
    lcd.print("SM Tank");//Tank
    lcd.setCursor(11, 1);
    lcd.setCursor(13, 2);
    lcd.print(readTemp(CTempSensorPin3));//SM TANK COLD
    lcd.setCursor(11, 2);
     if (hour() >= 8 && readTemp(HTempSensorPin0) >=97)//=F  100F or 37.78C         8 AM
     digitalWrite(8,LOW);
    if (hour()<=20 && readTemp(HTempSensorPin0) <=88)//=F 88F or 31.11C              8 PM
     digitalWrite(8,HIGH);
   if (hour() >= 8 && readTemp(HTempSensorPin1) >=97)//=F 100F or 37.78C            8 AM
     digitalWrite(9,LOW);
   if (hour() <= 20 && readTemp(HTempSensorPin1) <=88)//=F 88F or 31.11C             8PM
     digitalWrite(9,HIGH);
   if (hour() >= 20 && readTemp(HTempSensorPin0) >=87)//=F 100F or 37.78C            12 AM
   if (hour() <= 8 && readTemp(HTempSensorPin0) <=78)//=F 88F or 31.11C             8AM
   if (hour() >= 20 && readTemp(HTempSensorPin1) >=87)//=F 100F or 37.78C            12 AM
   if (hour() <= 8 && readTemp(HTempSensorPin1) <=78)//=F 88F or 31.11C             8AM
   if (hour() >= 20 && readTemp(HTempSensorPin0) >=87)//=F 100F or 37.78C            8PM
   if (hour() <= 8 && readTemp(HTempSensorPin0) <=78)//=F 88F or 31.11C             12AM
   if (hour() >= 20 && readTemp(HTempSensorPin1) >=87)//=F 100F or 37.78C            8PM
   if (hour() <= 8 && readTemp(HTempSensorPin1) <=78)//=F 88F or 31.11C             12AM
In what line please? The compiler tells you.
Also, the Time library has a 12 hour conversion built in:
int     hourFormat12();    // the hour now in 12 hour format
It would behoove you to use it.
I was trying to add it to between line 77 and 78.
Something like...
If (hour()<12)
hour()=hour()-12;
I also tried adding
int hourFormat12();
I got it. I was missing hourFormat12() in one of the display settings.
    lcd.clear();
The
curly
braces
are
useless
robmawe91:
You didn't get it. It's not a setting. It's a way of fetching the hour data.
