Hi guys ! I'm working right now with my project that the text message from GSM module will display on RGB LED Strip , if have conditions using text message ; View AllMessage , Delete AllMessage , Delete Message # ,Display AllMessage , if the textmessage is not the conditions above , it will automatically stored in a array (that the message that will display on RGB LED Strip)
But when i started to text Display AllMessage( display all message that saved in array) and text again some message it only read 12 characters in my text . Are my arduino is too busy to display message in RGB Led strip so that when i text again it only accept only 12 characters ? help me guys the code is below . And i uploaded pictures , i texted 3 messages that will display on array , " The Legend of Avatar " and etc . then I texted Display Allmessage ( to display in RGB ) the 4th text is also " The Legend of Avatar " but it in serial monitor it cut on 12 characters only
if(mySerial.available()>0){
Message = mySerial.readString();
Message=Message.substring(Message.indexOf("+CMT"));
Message=Message.substring(Message.indexOf("\n"));
Message.replace("\n","");
Serial.println(Message);
if(Message.indexOf("View Message")>=0){
mySerial.println("AT+CMGS=\"+639290584072\"\r"); // Replace x with mobile number
for(int i=0; i <5; i++){
mySerial.println("Text: "+ text[i]);// The SMS text you want to send
delay(100);
mySerial.println((char)26);// ASCII code of CTRL+Z
else if(Message.indexOf("Delete AllText")>=0){
for(int i = 0; i < 5; i++){
text[i] = "";
//Delete Message
else if (Message.substring(0, 11) == "Delete Text") {
Message.remove(0,11);
text[Message.toInt() - 1] = "";
else if(Message.indexOf("Display AllMessage")>=0){
j = 1;
else {
if(Message == ""){
Serial.println("");
else{
text[i] = Message;
Serial.print("Message Stored!");
Serial.println(i);
i++;
if( j == 1){
matrix->fillScreen(0);
matrix->setCursor(1, 1);
matrix->setTextColor(colors[i]);
matrix->print(text[i]);
matrix->show();
if(i == 4){
i = 0;
