12 switches pressed down at the same time - does it work?
Hi there, I'm creating a switchboard with twelve switches. I've programmed it so that each switch is a key on the keyboard when not pressed and all keys are X when pressed. All twelve switches will be pressed down at the same time (key X times 12). If I stat a program that needs to react on X it won't work. Does it has anything to do with so many keys being pressed down at the same time? If so, how do I solve it?
That might depend on how the switches are wired. Or it might be a coding problem.
Fix the wiring or fix the code.
The wire is OK... I'm guessing it's the code that's the problem somehow. It works fin when put in to a .jar-file, but not when it's controlling the program.
In the Java-code I've written:
 if (inputLine.equals("Button_high")) {
      try {
       Robot robot = new Robot();
       robot.keyPress(KeyEvent.VK_X);
       robot.delay(100);
       robot.keyRelease(KeyEvent.VK_X);
      } catch (AWTException e) {
       e.printStackTrace();
But the thing is, will this code work when X is pressed from 12 sources at the same time?
How the heck do you put C++ code in a jar file?
In the Java-code I’ve written:
Where is this Java code running ?
Certainly not on the Arduino.
