Hello.
I have a question.
How can I connect this motor :
to a L293D driver?
I have searched but I have not found anything...
A diagram will help me.
Thanks!!!
Hello.
I have a question.
to a L293D driver?
Thanks!!!
What is the stall current of the motor? Do you know that the L293 has the current capability to drive that motor? Can you post a data sheet for the motor?
There must be a million tutorials on the Internet on setting up an Arduino and L293 to drive a DC motor. What is it that you do not understand?
The six wires are likely two for DC power (Red for plus and Black for minus?) and four for a quadrature encoder. Some specs say 300 pulses per revolution.
You may have to take off the plastic encoder cover and trace the wires to figure out which wire is which. A similar motor shows the encoder wires as being:
Blue +5V
Green Ground
White EncA
Yellow EncB
Can you give me a diagram?
I usually use simple motors with 2 wires connecting to l293d , but it it the first time I use motors with 6 wires.
arduiNICK:
Red and Black go to the L293D. Ignore the other four unless you want to use the encoder.
