I'm sure this answer is hidden among the posts but I looked and looked. So here goes...
First project with Arduino and do not want to fry the board...
I have an Arduino Uno Wifi Rev2... i want to power it with a DC power supply into with the 2.1mm adapter on the Uno board. The supply puts out 12.35 VDC according to meter. The scope shows a nice flat, no ripple, filtered DC voltage as well. I plan to digital "write" one opto-isolated relay and "read" one current analog input.
I know the specs say 6-20 and i also know alot of people say 9volts is the sweet spot... I am just wondering if this will overheat the regulator? Power consumption as I intend to use "right now" is rather small... Maybe worry more as I expand the use of the board in the future or....
I recently did a project that ran on an Uno. The Uno was powered with a 12V wall-wart into the 2.1mm plug. The 5V pin was powering a Wemos D1 Mini. It would run for several hours with never a problem and the regulator was always cool to the touch.
But, for 24/7 use, I would use a 5V regulator from the 12V supply and power the Uno through the 5V pin.
SteveMann:
But OP has an Uno Wifi Rev2, not an Uno.
The only similarity is the size and the wrongly chosen name.
The Uno Wifi Rev2 has a built-in buck converter.
Not sure why they put 7-12volt in the specs. The MPM3610 buck chip has a >20volt rating.
The input cap might be 16 volt??
