Hello all. New to the arduino and I am looking for the answer to a question that I can't seem to find anywhere. I hope you guys can help.
I am looking at building a fireworks 12 cue sequencer off an arduino that triggers off of a 12 volt pulse from another firing system that in turn runs the programmed sketch. The "main" firing system would send a 12 volt 1-2 second pulse out of it's cue triggering some sort of sensor, mabey an optoisolator, which would close the circut hooked into the arduino input(s) and run the sketch. The outputs would close another optoisolator or relay allowing 12 volts from the units internal battery to flow out and fire the e-matches. Just wondering if this could be acomplished with the any of the arduinos, making the output(s) "look" for a ,for better words, "continuity" signal to run the sketch. I've see many of the sensors that can be used, but none of the fit the project. Any help would be greatly appreciated. Thanks ![]()
