1284P UART Upload, Problem uploading to board.
Hi, trying to upload my code via UART with DTR connected via capacitor to reset. The board resets when upload is initiated, but still fails to accept the new code. It works fine via ISP. I have burned bootloader via Arduino using USBasp.
Currently using MightyCore 1.0.8
Is there a fuse I need to set, or do I simply have the wrong bootloader?
Boards.txt
#### ATmega1284/P ####
1284.name=ATmega1284
1284.upload.tool=avrdude
1284.upload.protocol=arduino
1284.upload.maximum_size=130048
1284.upload.maximum_data_size=16384
1284.bootloader.tool=avrdude
1284.bootloader.unlock_bits=0x3f
1284.bootloader.lock_bits=0x0f
1284.build.core=MightyCore
1284.build.board=AVR_ATmega1284
# Pinouts
1284.menu.pinout.standard=Standard
1284.menu.pinout.standard.build.variant=standard
1284.menu.pinout.bobuino=Bobuino
1284.menu.pinout.bobuino.build.variant=bobuino
# Variants
1284.menu.variant.modelP=1284P
1284.menu.variant.modelP.build.mcu=atmega1284p
1284.menu.variant.modelNonP=1284
1284.menu.variant.modelNonP.build.mcu=atmega1284
# Brown out detection
1284.menu.BOD.2v7=2.7v
1284.menu.BOD.2v7.bootloader.extended_fuses=0xfd
1284.menu.BOD.4v3=4.3v
1284.menu.BOD.4v3.bootloader.extended_fuses=0xfc
1284.menu.BOD.1v8=1.8v
1284.menu.BOD.1v8.bootloader.extended_fuses=0xfe
1284.menu.BOD.disabled=Disabled
1284.menu.BOD.disabled.bootloader.extended_fuses=0xff
# Compiler link time optimization
1284.menu.LTO.Os=Disabled (default)
1284.menu.LTO.Os.compiler.c.extra_flags=
1284.menu.LTO.Os.compiler.c.elf.extra_flags=
1284.menu.LTO.Os.compiler.cpp.extra_flags=
1284.menu.LTO.Os.ltoarcmd=avr-ar
1284.menu.LTO.Os_flto=Enabled
1284.menu.LTO.Os_flto.compiler.c.extra_flags=-Wextra -flto
1284.menu.LTO.Os_flto.compiler.c.elf.extra_flags=-w -flto
1284.menu.LTO.Os_flto.compiler.cpp.extra_flags=-Wextra -flto
1284.menu.LTO.Os_flto.ltoarcmd=avr-gcc-ar
# Clock frequencies
1284.menu.clock.16MHz_external=16 MHz external
1284.menu.clock.16MHz_external.upload.speed=115200
1284.menu.clock.16MHz_external.bootloader.low_fuses=0xf7
1284.menu.clock.16MHz_external.bootloader.high_fuses=0xd6
1284.menu.clock.16MHz_external.bootloader.file=optiboot_flash/{build.mcu}/optiboot_flash_{build.mcu}_{upload.speed}_{build.f_cpu}.hex
1284.menu.clock.16MHz_external.build.f_cpu=16000000L
1284.menu.clock.20MHz_external=20 MHz external
1284.menu.clock.20MHz_external.upload.speed=115200
1284.menu.clock.20MHz_external.bootloader.low_fuses=0xf7
1284.menu.clock.20MHz_external.bootloader.high_fuses=0xd6
1284.menu.clock.20MHz_external.bootloader.file=optiboot_flash/{build.mcu}/optiboot_flash_{build.mcu}_{upload.speed}_{build.f_cpu}.hex
1284.menu.clock.20MHz_external.build.f_cpu=20000000L
1284.menu.clock.18_432MHz_external=18.432 MHz external
1284.menu.clock.18_432MHz_external.upload.speed=115200
1284.menu.clock.18_432MHz_external.bootloader.low_fuses=f7
1284.menu.clock.18_432MHz_external.bootloader.high_fuses=0xd6
1284.menu.clock.18_432MHz_external.bootloader.file=optiboot_flash/{build.mcu}/optiboot_flash_{build.mcu}_{upload.speed}_{build.f_cpu}.hex
1284.menu.clock.18_432MHz_external.build.f_cpu=18432000L
1284.menu.clock.12MHz_external=12 MHz external
1284.menu.clock.12MHz_external.upload.speed=57600
1284.menu.clock.12MHz_external.bootloader.low_fuses=0xf7
1284.menu.clock.12MHz_external.bootloader.high_fuses=0xd6
1284.menu.clock.12MHz_external.bootloader.file=optiboot_flash/{build.mcu}/optiboot_flash_{build.mcu}_{upload.speed}_{build.f_cpu}.hex
1284.menu.clock.12MHz_external.build.f_cpu=12000000L
1284.menu.clock.8MHz_external=8 MHz external
1284.menu.clock.8MHz_external.upload.speed=57600
1284.menu.clock.8MHz_external.bootloader.low_fuses=0xf7
1284.menu.clock.8MHz_external.bootloader.high_fuses=0xd6
1284.menu.clock.8MHz_external.bootloader.file=optiboot_flash/{build.mcu}/optiboot_flash_{build.mcu}_{upload.speed}_{build.f_cpu}.hex
1284.menu.clock.8MHz_external.build.f_cpu=8000000L
1284.menu.clock.8MHz_internal=8 MHz internal
1284.menu.clock.8MHz_internal.upload.speed=38400
1284.menu.clock.8MHz_internal.bootloader.low_fuses=0xe2
1284.menu.clock.8MHz_internal.bootloader.high_fuses=0xd6
1284.menu.clock.8MHz_internal.bootloader.file=optiboot_flash/{build.mcu}/optiboot_flash_{build.mcu}_{upload.speed}_{build.f_cpu}.hex
1284.menu.clock.8MHz_internal.build.f_cpu=8000000L
1284.menu.clock.1MHz_internal=1 MHz internal
1284.menu.clock.1MHz_internal.upload.speed=9600
1284.menu.clock.1MHz_internal.bootloader.low_fuses=0x62
1284.menu.clock.1MHz_internal.bootloader.high_fuses=0xd6
1284.menu.clock.1MHz_internal.bootloader.file=optiboot_flash/{build.mcu}/optiboot_flash_{build.mcu}_{upload.speed}_{build.f_cpu}.hex
1284.menu.clock.1MHz_internal.build.f_cpu=1000000L
Snake____1:
When you do a Sketch > Upload Using Programmer the bootloader is erased. After doing that you always need to do a Tools > Burn Bootloader again before you can do a UART upload.
pert:
Thanks! This is very helpful, this actually worked!
