12864A
hello
1 have a 12864A GLCD, i, using the latest IDE, and latest library from her:
http://playground.arduino.cc/uploads/Code/LCD12864.zip
but i cant make it work, im sure pin configuration is correcet as i used the same configuration at the library, and i manged to control contrast.
but the example want combile, i tryed a lot but always alot of errors, should (LCDA.Initialise();) command be in the setup() function, and this is enough to intialise the library? please help.
Lets try to draw a Circle, and a the number 012 on screen
First, we Initialise the LCD
LCDA.Initialise();
Let's delay a little bit
Now to start the rendering process (graphics on)
LCDA.Render();
Lets draw a circle
LCDA.DrawCircle(30,135,5);
The circle has been drawn to an off screen buffer, time to draw it on screen!
LCDA.RenderScreenBuffer(2); // lets draw it in the second screen
O.K. we said we need some characters in there as well. So lets enable ASCII mode and delay (we need at least 1 ms delay):
LCDA.Draw(false,4,0);
delay(1);
If we convert the characters '0', '1', and '2' we get the following 8 bit binary:
LCDA.setPins(1,0,0,0,1,1,0,0,0,0);
LCDA.setPins(1,0,0,0,1,1,0,0,0,1);
LCDA.setPins(1,0,0,0,1,1,0,0,1,0);
Now to wrap it all up, we set Draw back to true, if you don't do this the circle won't appear
