Hi all! I'm hoping this is a well known and easy issue to solve... I have some code that was running fine using this Adafruit OLED (128 x 32) Picture Here
The board is a little large, so I have purchased some of these from AliExpress - they should be the same kind of OLED, same size and same communication type. Though when I plug in the new display, it doesn't start up... Is there an obvious problem here or something that requires some proper thought..?
Slave modules for I2C should in general not include the pull-up resistors as the correct pull-up is only determined when all the devices on the bus are connected. While there is nothing intrinsically incorrect about having multiple terminations (pull-ups), it is the combined shunt resistance that matters.
