12cdev.h
I am having trouble including this in a sketch. I have downloaded the file into my libraries but the sketch still does not recognize it. Any suggestions?
is there a typo in the filename?
Can you post the sketch and the .h file so we can reproduce?
Have you restarted all instances of the IDE?
Which version of the IDE are you using? Which board?
Which you couldn't be bothered to post? Good luck.
As a new person to this programming I am not too familiar with the rules for asking for help. Please be a little patient with the new people… A gentle reply as Robtillaart has stated makes me want to keep posting and not feel to dumb.
A hostile response as AWOL just makes me not want to ask questions. It is not conducive to a friendly learning environment. But I do thank you for your help.
Here are my thoughts, I added the I2cdev.h file to the library in the Arduino folder. For what ever reason when I try to compile the program it does not find this file… I am new to this and may need a step by step instruction.
Again; thank you for all your help.
Here is the Sketch I am having trouble with.
// SainSmart Instabots Upright Rover rev. 2.0
// http://www.sainsmart.com
#include <Wire.h>
#include <SPI.h>
#include <Mirf.h>
#include <nRF24L01.h>
#include <MirfHardwareSpiDriver.h>
#include <I2Cdev.h>
#include <MPU6050.h>
MPU6050 accelgyro;
MPU6050 initialize;
int16_t ax, ay, az;
int16_t gx, gy, gz;
#define Gry_offset 0
//The offset of the gyro
#define Gyr_Gain 16.348
#define Angle_offset -26.96 // The offset of the accelerator
#define RMotor_offset 0// The offset of the Motor
#define LMotor_offset 0 // The offset of the Motor
#define pi 3.14159
float kp, ki, kd;
float Angle_Raw, Angle_Filtered, omega;
float Turn_Speed = 0, Turn_Speed_K = 0;
float Run_Speed = 0, Run_Speed_K = 0;
float LOutput,ROutput;
unsigned long preTime = 0;
unsigned long lastTime;
float Input, Output;
float errSum, dErr, error, lastErr;
int timeChange;
int TN1=3;
int TN2=4;
int ENA=9;
int TN3=5;
int TN4=6;
int ENB=10;
struct Axis // Datas from remote control
uint16_t axis_1;
uint16_t axis_2;
uint16_t axis_3;
uint16_t axis_4;
uint16_t axis_5;
uint16_t axis_6;
uint16_t axis_7;
uint16_t axis_8;
Axis axis_x;
struct Gesture // Datas send back to remote control
float angle;
float omega;
int speed;
int P;
int I;
int D;
uint16_t null_1;
uint16_t null_2;
Gesture data;
Wire.begin();
/* If the robot was turned on with the angle over 45(-45) degrees,the wheels will not spin until the robot is in right position. */
accelgyro.initialize();
initialize.setFullScaleGyroRange(MPU6050_GYRO_FS_2000);;
for(int i = 0; i < 200; i++) // Looping 200 times to get the real gesture when starting
Filter();
if (abs(Angle_Filtered) < 45) // Start the robot after cleaning data
omega = Angle_Raw = Angle_Filtered = 0;
Filter();
Output = error = errSum = dErr = Run_Speed = Turn_Speed = 0;
myPID();
pinMode(TN1,OUTPUT);
pinMode(TN2,OUTPUT);
pinMode(TN3,OUTPUT);
pinMode(TN4,OUTPUT);
pinMode(ENA,OUTPUT);
pinMode(ENB,OUTPUT);
// 24L01 initialization
Mirf.spi = &MirfHardwareSpi;
Mirf.init();
Mirf.setRADDR((byte *)“serv1”);
Mirf.payload = 16;
Mirf.config();
Filter();
Serial.print(" Angle = ");
Serial.print(Angle_Filtered);
// If angle > 45 or < -45 then stop the robot
Recive();
myPID();
PWMControl();
analogWrite(ENA, 0); // Stop the wheels
analogWrite(ENB, 0); // Stop the wheels
for(int i = 0; i < 100; i++) // Keep reading the gesture after falling down
Filter();
if(abs(Angle_Filtered) < 45) // Empty datas and restart the robot automaticly
for(int i = 0; i <= 500; i++) // Reset the robot and delay 2 seconds
Filter();
myPID();
void Recive()
if(!Mirf.isSending() && Mirf.dataReady()){ // Read datas from the romote controller
Mirf.getData((byte *) &axis_x);
Serial.print(“axis_1=”);
Serial.print(axis_x.axis_1);
Serial.print(" axis_2=");
Serial.println(axis_x.axis_2);
Serial.print(" axis_3=");
Serial.print(axis_x.axis_3);
Serial.print(" axis_4=");
Serial.print(axis_x.axis_4);
Serial.print(" axis_5=");
Serial.print(axis_x.axis_5);
Serial.print(" axis_6=");
Serial.print(axis_x.axis_6);
Serial.print(" axis_7=");
Serial.print(axis_x.axis_7);
Serial.print(" axis_8=");
Serial.println(axis_x.axis_8);
Mirf.setTADDR((byte *)“clie1”);
Mirf.send((byte *) &data); // Send datas back to the controller
if(axis_x.axis_1 >= 520) // Y axis datas from joystick_1
Turn_Speed = map(axis_x.axis_1, 520, 1023, 0, 30); // 30 is the max turning speed, you can set it yourself
else if(axis_x.axis_1 <= 480)
Turn_Speed = map(axis_x.axis_1, 480 ,0, 0, -30); // 30 is the max turning speed, you can set it yourself
Turn_Speed = 0;
if(axis_x.axis_2 >= 520) // X axis datas from joystick_1
Run_Speed_K = map(axis_x.axis_2, 520, 1023, 0, 30); // 50 is the max running speed, you can set it yourself
Run_Speed += Run_Speed_K;
else if(axis_x.axis_2 <= 480)
Run_Speed_K = map(axis_x.axis_2, 480, 0, 0, -30); // 50 is the max running speed, you can set it yourself
Run_Speed_K = 0;
axis_x.axis_1 = axis_x.axis_2 = 500;
void Filter()
// Raw datas from MPU6050
accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
Angle_Raw = (atan2(ay, az) * 180 / pi + Angle_offset);
omega = gx / Gyr_Gain + Gry_offset;
// Filters datas to get the real gesture
unsigned long now = millis();
float dt = (now - preTime) / 1000.00;
preTime = now;
float K = 0.8;
float A = K / (K + dt);
Angle_Filtered = A * (Angle_Filtered + omega * dt) + (1 - A) * Angle_Raw;
// Preparing datas which need to be shown on the LCD.
data.omega = omega;
data.angle = Angle_Filtered;
void myPID()
// You can see the values both on the serial monitor and the remote controller.
// Watch the tutorial video on youtube.
kp = analogRead(A0) * 0.1; Serial.print(" kp = “); Serial.print(kp);
ki = analogRead(A1) * 0.0005; Serial.print(” ki = “); Serial.print(ki);
kd = analogRead(A2) * 1.0; Serial.print(” kd = "); Serial.print(kd);
data.P = analogRead(A0);
data.I = analogRead(A1);
data.D = analogRead(A2);
// Calculating the output values using the gesture values and the PID values.
timeChange = (now - lastTime);
lastTime = now;
error = Angle_Filtered; // Proportion
errSum += error * timeChange; // Integration
dErr = (error - lastErr) / timeChange; // Differentiation
Output = kp * error + ki * errSum + kd * dErr;
lastErr = error;
LOutput = Output - Turn_Speed + Run_Speed;
ROutput = Output + Turn_Speed + Run_Speed;
data.speed = (LOutput + ROutput) / 2;
void PWMControl()
if(LOutput > 0)
digitalWrite(TN1, HIGH);
digitalWrite(TN2, LOW);
else if(LOutput < 0)
digitalWrite(TN1, LOW);
digitalWrite(TN2, HIGH);
digitalWrite(ENA, 0);
if(ROutput > 0)
digitalWrite(TN3, HIGH);
digitalWrite(TN4, LOW);
else if(ROutput < 0)
digitalWrite(TN3, LOW);
digitalWrite(TN4, HIGH);
digitalWrite(ENB, 0);
analogWrite(ENA, min(255, (abs(LOutput) + LMotor_offset)));
analogWrite(ENB, min(255, (abs(ROutput) + RMotor_offset)));
At the top of every significant section of the forum, we post a sticky thread which sets out a few simple ideas to help you get help. We even highlight the title in bold
But you couldn't be bothered to read it, and then you berate us.
You keep talking about I2cdev.h, but your code refers to I2Cdev.h
These are not the same. Capitalization matters.
This is why we want the code posted.
Also: And, despite Robtillaart's "gentle reply", you haven't answered all of his questions. This is bound to get smart people like AWOL going. Robtillaart and AWOL are providing free help, but you MUST help them to help you - or you can go elsewhere.
vaj4088: You keep talking about I2cdev.h, but your code refers to I2Cdev.h
. . . and the thread title refers to "12cdev.h", which is swapping digits for letters.
Everyone here provides their time for free - do you really want to waste it?
I am using the IDE Arduino 1.6.4 With the Arduino Uno board. Yes I have restarted all new Thanks for the tip about the case sensitive names I will try this...
AWOL: . . . and the thread title refers to "12cdev.h", which is swapping digits for letters. Everyone here provides their time for free - do you really want to waste it?
Thank You for your help. I did manage to swap letters for numbers. When I re-arranged them it worked. For a newbie this can get quite confusing at times. especially when I have very little programming experience.
Thanks once again
