12V 10A PSU, these are dangerous...right?
I was browsing eBay and saw these 12V power supplies with 2.1mm barrel connectors, which supports up to 10A of current. http://www.ebay.com/itm/AC-100V-240V-to-DC-12V-1A-2A-3A-5A-6A-8A-10A-Power-Supply-Adapter-transformer-/201539355844?var=&hash=item2eecae84c4:m:mtl22u9oC1ikjKyVXqoxcFA. These can't be safe, am I right? I don't think the wire gauge itself may be able to support that amount of current, but I am pretty sure those 2.1mm connectors aren't made for it. It seems like a potential fire hazard. Someone correct me if I am wrong.
:smiling_imp: eBay :smiling_imp:
From what I recall, barrel connectors are rated for 1 or 2 amps.
...But I think my laptop power supply is rated at ~4 Amps.
2.1 x 5.5mm connectors are available rated for up to 8A at least. 5A is common. So yeah, I'd be a little uncomfortable putting 10A through a single barrel jack....
If it’s unsafe to draw 10A through a barrel connection the device the draws 10A through a barrel connection is unsafe in the first place. :confused:
Highest rated I see at Digikey is 8A.
http://www.digikey.com/product-search/en/connectors-interconnects/barrel-power-connectors/1443096?k=2.1mm&k=&pkeyword=2.1mm&pv574=16&FV=fff40016%2Cfff80518&mnonly=0&newproducts=0&ColumnSort=0&page=1&stock=1&quantity=0&ptm=0&fid=0&pageSize=25
What are you powering? Does it draw 10 amps?
DrAzzy:
CrossRoads:
DVDdoug:
Thanks for the tips. I use these connectors quite often, and never felt comfortable passing anything above 5A through, as the connectors(that I use) do feel a tad warm above that.
ChrisTenone:
janerlve:
Good observation. What happens is a 2.1mm splitter can be used on such "higher amp" power supplies, to output to multiple devices at the same time.
Byork:
... What happens is a 2.1mm splitter can be used on such "higher amp" power supplies, to output to multiple devices at the same time.
That splitter is a possible weak point in a high amp situation.
