12V 5W light bulb load on a L9110 bridge?
Hi
I need to turn on and off a 12V 5W incandescent light bulb,
When the bulb is lit its internal resistance is 30ohm and the 400mA continous current it is safe for the L9110's output
But when cold it's only 2-2.5 ohm, the startup peak current can reach 5-6A, may I assume the 100ms time to heat the filament safe for the L9110 transient output of max 2A or not?
Thanks
I couldn't find any detailed information regarding the 2A max test conditions. They are made to pull 800mA continuously. At a couple bucks each I would smoke test one. If it does work, reliability might be in issue down the road.
Anthony
If the datasheet says peak current limit is 2A, I would definitely not expect it to be happy carrying 5A,
that's an increase in I-squared by a factor of 6 above the spec.
Thank you for the answers.
I'll take my chances with a series 100-400uH inductor, feed it short (10-20? microsecond) pulses until the bulb gets warm then I expect to be able to switch to continuous current. The L9110 includes flyback diodes
One drawback is when something goes wrong with the program and it skips this warm-up.
Good luck - I'd just use a suitable logic level MOSFET which will just work.
